![]() Just breaking them in. Exeptional bass from 7" Seas H1215. Cabinet very heavy at 125lbs. I wasn't sure about going the 2-way route on this one so I have both tweeter and mid wires routed through seperate upper chamber for easy changeover. Space above tweeter will fit a Morel small face or the Vifa D26NC55. Current tweeter cutout is exact fit for any of the Vifa 4" mids. X-over is velcro-mounted on a slanted board below woofer. Removable turnbuckle side brace facilitates easy removal of x-over. |
#2 |
Very nice looking speakers to say the least.
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#3 |
I saw your project before in this thread:
Cloneable commercial speakers Very nice finishing, beautiful picture!
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#4 |
Nice work Polykmon!!
![]() What type of finish is that? |
#5 |
What a beauty!! What is the finish?
The base is similar in concept to what I'm building (but won't be done for a while).
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#6 |
*Very* nice!
I'd personally like to see Troels HESII (Vifa version) done with a cabinet shaped similar to this particular Kharma esthetic.. http://www.troelsgravesen.dk/HES_II.htm High Eff., Good Looks, Excellent Sound.. (..just dreaming. )
perspective is everything |
#7 | ||
First I sealed the mdf then three coats of Rustoleum Sandable Auto Primer. ![]() Finished with 6 coats of Duplicolor Truck/Van Spray paint ( Dark Garnet Red) and 6 coats of Deft Spray Lacquer. Looks lighter in pics but actually quite dark. I have a few days before I can buff out the finish and top with Minwax furniture wax. I can use the rest as my arms are aching from moving these things around. Although they sound great already I can't help thinking what they would sound like with a 7" Revelator or C95 T-6 with a 9500 or 9900. Or just adding Vifa 4" mid and D26NC55 to make it a three way. Any thoughts? |
#8 |
Great work! The baffle edges look like more than a simple roundover...how did you get that look?
#9 | |
Drew a vertical line 3" from front face on sides/top and sculpted by hand. Yes a lot of work! Contour gauge helped. Sides and top are 1 1/2 " thick. |
#10 |
| Another Speaker Finished (MTM Floorstander) | Vikash | Multi-Way | 8 | 23rd December 2006 02:15 AM |
| Floorstander | Alexnick | Multi-Way | 11 | 16th December 2005 06:16 PM |
| Vifa P17/D25 floorstander + XLS subwoofer finished! | tktran | Multi-Way | 14 | 26th July 2005 07:19 AM |
| floorstander | Guss | Multi-Way | 15 | 26th July 2003 02:00 PM |
| Page generated in 0.10887 seconds (82.00% PHP - 18.00% MySQL) with 10 queries |
