Hi, can this audax be used for open baffel.I will use six pr. side.
crossover 300hz http://www.hautparleur.fr/_audax/hp210m0.pdf |
#2 |
With that Q, they would work fine IMO. With 6 drivers, you'll get about 1400 square centimeters of piston area, and at 4mm x-max, I don't see why you wouldn't cross over lower, maybe 80-100hz depending on baffle size.
Are you going to run them all up to the tweeter crossover? How will you wire them? My preference would be to run one up to the tweeter, and bring the others in at a lower frequency-a 2.5 way. That may require an odd number of drivers per side though. That's my .02cents Variety is the spice of life, Jason
Unbaffled |
| "Linesource with one tweeter? | TroelsM | Multi-Way | 1 | 19th November 2007 10:43 AM |
| Open call for suggestions on Open Source DIY Audio Design | gfergy | Everything Else | 1 | 15th April 2007 07:33 AM |
| Open Source, Open Architecture! | zenmasterbrian | Digital Source | 185 | 23rd February 2007 10:35 PM |
| open baffel acoustic short cut | pk2carlos | Multi-Way | 7 | 20th June 2003 06:16 PM |
| Page generated in 0.06618 seconds (66.71% PHP - 33.29% MySQL) with 10 queries |
