#11 |
psych - i dont want to make an enemy of you.I just asked for help with x-over.Lot of yous used this speakers that i am using, so i expected some contribution to this thema.In my opinion there is no thing such as PERFECT LOUDSPEAKER, wich can reproduce the sound 100% naturaly.No matter how hard you try, a couple litres of volume can not replace the whole orchester.I am not a profesional, just want something SELFMADE, thats also sound nice, is not screaming, and is a little bit designed to my tastes....so please no fighting.....i mean no harm
I would appriciate if you have any suggestions to these speakers, that i have in mind.Such as - is the tweeter good enough for the mid/sub? What should i be looking for in the XO with this particular midd/bass driver etc. etc. Anyway, thanks for your insight in things "loudspeakers". Danny |
#12 |
Danny,
do you own any Test Equipment ? Such as a Multimeter with an AC Voltage range ? and an Audio Frequency generator or Sine-wave oscillator ? Do you have the Data Sheet for the G18RNX/P ? If not, then go to:- THE ART OF SOUND PERFECTION BY SEAS - Home and look on the "Vintage Drivers" page, and in "Prestige Woofers" there. This looks like a good driver, thus is worth making a good cross-over for it, and a suitable cabinet . Why do you want to squeeze it into a very small 8 litre cabinet ? In a much larger cabinet it can be made to work down to 60 Hz or 70 Hz, and with suitably low Q then for the driver-in-cabinet bass roll-off to be used as part of the cross-over for when you use it with a sub-woofer. It will play OK bass itself in a suitable cabinet if you have a small room, but if you want high volume level in a large room , then a 10" added for low bass will be needed. You do not need an expensive ScanSpeak 10" for good low bass in a sealed cabinet - - there is a suitable 10" SEAS. Choice of tweeter depends on at what frequency you decide to cross over from the G18. After inspection of the Data Sheet, I see two obvious frequency areas to cross at:- around 2kHz, and around 4kHz. If you cross at 4kHz, the smooth slope of the driver's roll-off can be used as part of the filter, but for good midrange sound you will need to listen on-axis to the G18, and that is not a problem if you use high stands - make suitable height stands - I do. You can then use the SEAS 19TFF1 tweeter, because that has good off-axis response to high frequencies, thus will give a well balanced sound combining with the G18 on-axis - if you get the cross-over design right. 19TFF1 can be crossed quite easily around 4kHz. If you cross at 2kHz you will need to use a tweeter which has a lower Fs than 19TFF1 has, and ideally one with an Fs well below 1kHz, but most of these do not have as good off-axis response to the highest treble as 19TFF1 has, except for a few expensive tweeters from other manufacturers. To design a suitable cross-over you will need some Test Equipment, and I think it better to spend money on that and not on an expensive ScanSpeak 10" driver. Make a good 2-way with the G18 SEAS, and then make the subwoofer later. What is your room size ? What are some critical-for-bass response recordings you own ?
Alan Last edited by alan-1-b; 19th October 2009 at 09:11 AM. |
| Transformer nightmare!?! | metallifornia | Parts | 1 | 3rd April 2008 07:14 PM |
| Shanling nightmare!!! | PhilM400 | Digital Source | 49 | 22nd February 2008 11:06 PM |
| SI nightmare | gvr4ever | Class D | 16 | 20th September 2006 05:20 AM |
| my titanic nightmare | chainenoble | Subwoofers | 1 | 20th May 2006 05:15 AM |
| Cartridge nightmare's | pete.a | Analogue Source | 14 | 5th December 2003 04:00 PM |
| Page generated in 0.08306 seconds (71.95% PHP - 28.05% MySQL) with 10 queries |
