Pardon the newbie if this has been coverred, but I could use some help.
I would like to use a variable l-pad for a 6 ohm tweeter. I can find 8 ohm l-pads. I understand that a stereo 8 ohm l-pad can be wired in parallel for a 4 ohm load. But what would be the best approach for a 6 ohm tweeter? Thank you! Ed |
#2 |
bump.
Anyone? I really want to have maximum chance of success. I would really appreciate the input of more experienced designers. Thanks in advance!!!!! Ed |
#3 |
an 8R L-pad should work OK with a 6R tweeter, though it depends on the exact crossover details. |
#4 |
Thanks for the reply!
My intention was to use surplus JBL L100t3 crossovers I own, but bypassing the existing fixed lpads on the xovers, and using the variables. I'm going to have to rithink this, however, as using the 6 ohm tweeter would also require my making other changes to the crossover. I guess I will either select a different tweeter, or build the crossover from scratch. Thanks again! |
#5 |
On a simplistic level simply put 2R is series with the tweeter. But many 8 ohm tweeters measure ~ 6R DCR. |
| Power load, dummy load (pic) | luka | Power Supplies | 43 | 9th February 2012 02:50 PM |
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 08:47 PM |
| Variable SMPS | TroelsM | Power Supplies | 0 | 30th January 2007 07:48 PM |
| Variable Low pass for sub | ThSpeakerDude88 | Chip Amps | 3 | 1st September 2006 11:55 PM |
| DIY active variable sub x-over? | darkmoebius | Subwoofers | 6 | 21st June 2005 03:39 PM |
| Page generated in 0.07352 seconds (71.49% PHP - 28.51% MySQL) with 10 queries |
