Old 20th October 2006, 09:49 PM   #1
qguy is offline qguy  Canada
Send a message via AIM to qguy Send a message via MSN to qguy Send a message via Yahoo to qguy
Default Reducing midrange
the midrange of my 2 way bookshelves is a little bit too forward for my taste, Can you direct me or show me a circuit for a passive x-0ver that would reduce the midrange output of my woofer in the 800-1200 range in 2db,4db,6db increments - thanks
na
Old 20th October 2006, 10:06 PM   #2
Send a message via AIM to joe carrow
This is just what I came up with googling for "passive notch filter":
http://www.diysubwoofers.org/bnd/notchfil.htm
I hope that's a helpful start.
Old 21st October 2006, 02:15 AM   #3
Im looking for something that does the opposite.
http://sound.westhost.com/project63.htm
However how do you make it so it doesnt attenuate frequencies outside the bandwidth range?
Old 21st October 2006, 03:45 AM   #4
owdi is offline owdi  United States
owdi's Avatar
Take it apart and look inside. You may be able to modify the crossover with some low cost parts to achieve what you want.
Dan
Old 21st October 2006, 04:48 AM   #5
I found a LCR circuit that uses the same woofer (usher 8945 ) that reduces the 900hz, the circuit calls for an inductor with a 1.0 mh value, I reckon I have to do my own winding, I found a calculator that addresses the gauge and number of turns, are there any advantage of using a thick wire vs a thin magnetic wire other than cost and size ?
na
Old 21st October 2006, 06:15 AM   #6
DC resistance.
reducing voltage rtill Solid State 28 16th January 2009 01:45 PM
reducing hum in SET amps pjpoes Tubes / Valves 8 2nd May 2007 12:32 AM
reducing output Lostcause Power Supplies 4 7th September 2006 09:50 PM
Reducing volume? barendh Solid State 16 5th September 2006 02:00 PM
reducing hum mrjcfreak Tubes / Valves 5 19th July 2004 02:26 PM
Page generated in 0.08652 seconds (73.94% PHP - 26.06% MySQL) with 10 queries
