The advice generally given with loudspeakers is not to position them too close to room boundaries, so as not to give a boomy response.
But with transmission line (TL) speakers, the port is very often positioned low down in the cabinet, and therefore close to the floor. Would it therefore be better to arrange the internal line folding such that the port emerged close to the drive unit, near the top of the cabinet ? After all, at the low frequencies, the port is responsible for half of the sound pressure. |
#2 |
The short answer is yes, and it is done, see Rega Naos, Seas Thor etc. |
#3 |
Hi There
The longer answer is "varies". The extra lift from the floor gives you the possibility to design much lower tuned tl's without a boomy bass. Something like this: Half tl This mini tl speaker is purposly built with floor and wall bass lift in mind. If used in small rooms it give's an even and very low bass. I designed it with the German program Aj-Horn. Best Regards Roland Breteler Crafty loudspeakers |
| Port in non-optimal position ? | RobWells | Subwoofers | 9 | 25th July 2009 10:51 PM |
| Woofer and port position | DragonMaster | Multi-Way | 2 | 13th September 2008 10:18 PM |
| Port position on Bass cab | Gubbe | Instruments and Amps | 1 | 17th February 2006 03:40 PM |
| Size and position of the port in a ML TQWT | teodorom | Multi-Way | 3 | 12th June 2004 01:57 PM |
| Port position? | MisterB | Multi-Way | 3 | 20th February 2002 03:42 PM |
| Page generated in 0.07794 seconds (67.09% PHP - 32.91% MySQL) with 10 queries |
