Hi I have an old Sony HCD-MD333 Mini System with blown tweeters. The speaker model is SS-MD333 2-way, bass reflex type and pictured here. The tweeter is a 2.5cm balanced drive.
![]() What do I need to know before replacing the tweeters in these speakers? Can I place any tweeter into these boxes or will I run the risk of damaging them? |
#2 |
Did it Himself
Because the design is probably not really very complex or even optimised that well, probably any tweeter that fits will do.
They were blown in the first place because the amp was driven into clipping, so as long as you don't do that again they should be OK. You can probably get proper replacements from SOny service
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
Great, I was hoping any new tweeter would do the job. Is there any risk of causing damage to the system or tweeter itself if I popped a slightly more powerful one in?
#4 | |
Edit: as already mentioned above you should replace your tweeters with the same model from Sony. This is mainly because they are rear mounted on a baffle designed for those specific drivers and installing a different tweeter would be difficult at best, if at all possible. Portable/mini audio systems are definitely not tweaker friendly. |
#5 |
It looks like a $6 Audax polymer dome type tweeter would glue right in there. Ask in one of those fly-by-night car audio shops. Just get the polarity right or it will sound worse than necessary. Try one before you spend big bucks from Sony. Either way, this cabinet appears easy to get inside for you to repair it yourself. Good luck.
#6 |
Sony got back to me this week with the news they no longer carry a replacement part. So it looks like I will replace the tweeters myself. I will try and match them as closely as possible with the current components.
Thanks for your help |
| Is it possible to fix the BLOWN tweeters? | Tony.ca | Multi-Way | 12 | 23rd February 2010 04:25 PM |
| Blown amp pre-amp in or HU pre-amp out? | scraph | Car Audio | 5 | 23rd January 2009 12:58 AM |
| Yamaha NS-1000X tweeters blown...whats the problem? | young_pup | Multi-Way | 10 | 1st October 2005 07:41 PM |
| Blown Tweeters | Ajaz | Multi-Way | 2 | 18th February 2004 12:04 AM |
| Blown woofer- Coil replace or Passive Radiator | CarMan | Multi-Way | 9 | 17th April 2003 02:40 AM |
