Hi!
What is the "rule" for the duct placement in the BR boxes? I mean how big distance need I keep between the duct and the driver?? How close should I put the port?? Greets: Tyimo |
#2 |
The general rule is to keep the opening of the port at least one diameter away from any side of the box.
It's good to give some space between the opening of the port and the driver. Mostly, you can build a box that fits the "golden ratio", and put the port behind the tweeter. If you can try to get the port opening near the center of the box, and that's not too within 2 or 3 port diameters of the woofer, then you should be in good shape. |
#3 | ||
Hi Joe!
Thanks! Quote:
Greets: Tyimo |
| Measuring driver's acoustic centrer, voice coil distance | wigginjs | Multi-Way | 2 | 3rd June 2007 03:21 AM |
| Question for the americans reagrding distance buy | Christer | The Lounge | 7 | 30th November 2005 02:12 AM |
| Distance between Woofer and Midrange driver | LageB | Multi-Way | 9 | 21st August 2003 05:53 AM |
| driver distance requiring shielding | timsch75 | Multi-Way | 3 | 3rd August 2003 06:13 PM |
| Any minimum distance from driver to port? | Circlotron | Multi-Way | 4 | 27th December 2002 11:23 PM |
| Page generated in 0.06524 seconds (68.51% PHP - 31.49% MySQL) with 10 queries |
