I am about to build speaker with scan speak drivers:21w8555-01,
18w8545 and 99000 revelator tweeter.I am in doubt which xo layout is better,2.5 way or 3way for given drivers. Speaker will be acoustic suspension. Deki. |
#2 |
Speakerholic
2.5 ways are best suited to identical bass drivers. Different units will sound different at the frequency overlap
#3 |
I was kinda wondering this too ... will either deliver (in general) benefits in certain areas? If I had to guess I'd say a 3 way would potentially be more detailed and clean in the midrange, but that the 2.5 way would have more bass volume and impact.
#4 |
As you state it depends on the given drivers as to which would be best. Attached is a series 2.5way for Scanspeak drivers, see source. |
#5 |
Speakerholic
I found the 2.5 way was effective when using smaller drivers like the CSS WR125's.
#6 |
Related...I think:
I was wondering about doing a 2.5 way where the .5 was ported and the other (same driver) was sealed. What major issues are there here? I see phase (~60deg) and a peak at F3 in group delay...anything else? Regards, Aaron Edit: the phase shift and group delay were specific to my model on RS125's using Zaph's measurements.
Regards, Aaron |
#7 | |
#8 |
'2.5 ways are best suited to identical bass drivers' - probably depends how low you cross them over; I'm currently using a 2.5 way with 5"Peerless mid-bass & oddball 8" bass units, crossed over at around 120Hz - I'm very happy with them.
5" & 8" units in separate cabs, both ported; the 8" units are EBS alignment (because they're both different units - cabs tuned differently to get same response). I'm going to try blocking the ports on the 5" cabs & add an extra cap in the xover to see how they sound, but with a touch of bass boost at the amp, this system sounds really solid & clear - love it... Cheers, Pete McK |
#9 |
Separate cabs usually involves LP bandpass filter effect on the mid and even without knowing the enclosure volumes involved I would imagine that frequency overlap between drivers is relatively narrow. Wouldn't such a configuration be considered a 3-way rather than a 2.5?
#10 |
I guess it ultimately is a 3-way with similar drivers. As I do not see any objections, I suppose the silence after the questions is actually saying "Try it!"
Regards, Aaron
Regards, Aaron |
| 3way Horn | CLS | Multi-Way | 4 | 25th June 2008 01:20 AM |
| 3way design | Paulus1981 | Multi-Way | 1 | 20th October 2007 09:40 PM |
| 3way with bandpass sub | tinitus | Multi-Way | 29 | 9th August 2007 03:01 PM |
| Page generated in 0.10712 seconds (70.23% PHP - 29.77% MySQL) with 11 queries |
