Old 16th October 2006, 03:56 PM   #1
bbchem is offline bbchem  United States
Send a message via AIM to bbchem Send a message via Yahoo to bbchem
Lightbulb Radio Shack Super Tweeter
I have a pair of Radio Shack Super tweeters and want to hook them up to my main speakers which are Single Driver. What do I need to buy to add them to the speakers binding posts???
I am an electronics illiterate
Old 16th October 2006, 04:23 PM   #2
Speakerholic
Cal Weldon's Avatar
Do you have a pic or two?
Is this the unit that sits on top and has a rounded blackish case with silver on the front and a little pointy thing in the center?
I'm just trying to remember if there is a built in XO or if that might be a piezo tweeter. Too many moons ago I'm afraid. Can you disassemble it before taking pics?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th October 2006, 04:27 PM   #3
Speakerholic
Cal Weldon's Avatar
Ah, the power of google
http://images.google.ca/imgres?imgur...lr%3D%26sa%3DN
This one? I see it's fully removeable from the housing for regular mounting. It also has a built in XO, albeit of questionable quality. If you wish to leave it in the housing you can just get some speaker wire, 18 ga. stranded will siffice and hook it up + to + and - to -
Old 16th October 2006, 08:38 PM   #4
Thumbs up Thanks Cal
Yes, that the one!! So I do not need anything else? I can hook it up directly to binding posts?? OK sound easy, my speakers are 89dbl/1w
Old 16th October 2006, 08:55 PM   #5
Variac is offline Variac  United States
diyAudio Editor
Variac's Avatar
It's not a piezo, 'cause it has a magnet, and if it is basically the same as the FT17 then it is pretty decent sounding. How much does it cost each?
Old 16th October 2006, 09:05 PM   #6
Your first DIY project! May it be successful!
You may find that moving the tweeter a little back and forward might make a difference. Also, placing it on a soft wool pad might help. Placement matters, because one wavelength at 5 kHz is about 2.6 inches, so phase relationships will matter.
As for the 89 dB/1W spec; I think I'd suggest considering the pad suggested in the RS manual. That's quite an efficiency difference. If you feel a piercing pain between the eyes, and your ears bleed a little, you will definitely want the level adjustment.
Set the level according to your preference.
Old 16th October 2006, 09:05 PM   #7
Speakerholic
Cal Weldon's Avatar
Originally posted by Variac
It's not a piezo
Which became blindingly obvious when I found the link.
They sure go back those units. I can remember using a pair when I was in high school, circa late seventies. Is it still being made I wonder? It was my introduction to the term supertweeter.
Old 16th October 2006, 09:28 PM   #8
Default Ebay
I paid $87 US dollars on ebay, probably to much, the last bid went from 40$ to 87$!
Thanks, Bill[B]
Old 16th October 2006, 09:30 PM   #9
Pano is offline Pano  United States
Pano's Avatar
I think they dropped this model about 8 years ago. There was a rush to buy up the reminaing stock. I missed out. Maybe wrong on how long ago....
Take the Speaker Voltage Test!
Old 16th October 2006, 09:38 PM   #10
Speakerholic
Cal Weldon's Avatar
Default Re: Ebay
Originally posted by bbchem
[B]I paid $87 US dollars on ebay
Yikes, I didn't realize they were so popular. They are a good tweeter as I remember but...
40-1377 Radio Shack Tweeter mummy Multi-Way 28 30th March 2009 01:16 AM
Radio Shack BrianDonegan Everything Else 0 23rd April 2007 05:27 PM
Radio Shack OPT! sorenj07 Parts 2 13th March 2007 02:30 AM
Radio-Shack 40-1278B Radial Horn Tweeter fireman Multi-Way 2 10th March 2004 12:56 AM
WTB Realistic (Radio Shack) 40-1377 Tweeter fboog Swap Meet 2 10th December 2003 08:11 AM
Page generated in 0.10498 seconds (77.29% PHP - 22.71% MySQL) with 10 queries
