Hi there,
I own a pair of paradigm v.2 reference floorstander loudspeaker and i have a problem with it. When i crank up the volume to a certain level the mid range starts to jarr,like it's bottiming out.I thought the bass was too high so i connected another pair of paradigm studio v.2 and its sounds perfect with the same volume. Can someone please help me figure out this problem since the floorstander should be able to take up more volume than the studio. picture of the speaker below Thanx, Tony |
#2 |
diyAudio Chief Moderator
We can help you, but Paradigm isnt the first to have a say? Did you contact them?
#3 |
I did ,they want me to take it to a dealer and so on ,was wondering if I would be able to fix it with of course any help i can get from this forum.
Thanx, Tony |
#4 |
Sounds like clipping to me - maybe try a more powerful amp.
Rob. |
#5 |
Speakerholic
Rob,
He said he switched speakers and it was fine. Tony, is the driver moving enough to be bottoming out? Are you able to do any testing? |
#6 |
Hi Cal,
He said he switched speakers to a different model - maybe the other speaker is a different impedance / easier to drive. Never mind. My bad. Rob. |
#7 |
I thought he said he simply connected more speakers. This would indeed have allowed him to get more bass volume, but not necessarily better sound quality. (J6P+$=Severely Disrepected Gear)
#8 |
It seems like that, something broken in the Xover of mid. the bass F power was into mid-driver and made it bottoming.
make it better. |
#9 |
Smells like a mechanical defect. Maybe some bad/loose glueing in neck/spider region.
#10 | ||
Speakerholic
| Cracking/Static in Pre-Amp | TheVille | Solid State | 2 | 17th April 2009 07:42 PM |
| Questions on reference and noise in the super regulator | Lucien | Power Supplies | 1 | 4th August 2008 09:08 PM |
| Cracking noise at clipping | ionutgaga | Class D | 24 | 27th July 2008 10:38 PM |
| Low noise higher voltage reference? | Onvinyl | Power Supplies | 4 | 24th July 2008 09:51 PM |
| cracking noise in P3a | PetarLD | Solid State | 0 | 13th May 2004 04:03 AM |
| Page generated in 0.09752 seconds (77.49% PHP - 22.51% MySQL) with 11 queries |
