#11 |
Also, for the 2.4 mH inductor do I just buy a 2.5 mH and shorten it up or something?
#12 |
Yes, best is to buy a LCR multimeter and meassure while you're unwinding it.
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#13 |
Is 2.5 mH close enough? Don't inductors have range of +/- 5%?
I can't get an LC meter |
#14 |
I think you'd be lucky to buy an inductor with a 5% tolerance, most likely it's 10-20%. Your drivers are likely to be 10% off nominal spec, too. The 2.5 is probably close enough.
You can make an impedance bridge with an opamp, a couple of 9V batteries and and a pair of resistors in about 10 minutes. http://www.arrl.org/qex/2005/Steber.pdf http://www.arrl.org/qexfiles/LMSprog.zip |
| Grounding Check please (diagram included) | redrabbit | Solid State | 10 | 15th October 2007 08:52 AM |
| Subwoofer Wiring Diagram | boris333 | Subwoofers | 10 | 4th October 2005 11:16 PM |
| I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) | Audiophilenoob | Chip Amps | 9 | 16th August 2005 04:37 AM |
| can i use this wiring diagram | mitchell | Car Audio | 3 | 23rd August 2004 08:50 PM |
| Page generated in 0.07154 seconds (72.99% PHP - 27.01% MySQL) with 10 queries |
