#661 |
The new JBL M2 uses a unity-ish arrangement for frequency range of 800hz to 20khz. It appears that there are two ring radiators, operating face-to-face, and the output of the rings are horn loaded via a common channel. Interesting stuff. This is the second time I've noticed JBL copping some Unity-type technology. (The first was the midranges in one of their array lines.) I wonder how similar this JBL dual diaphragm ring radiator is to BMS's dual diaphragm ring radiator? Some pics of the response, to give you an idea of it's performance. ![]() Also, for lulz, here's a pic of my first horn speakers, which I bought based on a positive review in Stereophile, back when I was an audio noob. Second pic are my Summas. Third pic is the JBL M2. I'm seeing a family resemblance here
#662 | |
The JBL D2 (used in the M2 loudspeaker) doubles diaphragm area in a small diameter driver, a good feature when multiple drivers are used in a vertical arrangement (as in their small format line array speakers), or when a low crossover point with low distortion is required, as in the M2. The BMS dual concentric could be thought of as "unity-ish", while the JBL D2 is just a far more elegant way of doing what was done with the old JBL 2329 "Y" throat adapter. Last edited by weltersys; 26th February 2013 at 10:13 PM. |
#663 |
Woah, is that a pair of HLS 810? I found one at the swapmeet, and was mad when the couldn't find the other one. I wanted a pair, and they were CHEAP. I had purchased a pair at cost when I worked for a consumer retailer back in the day. Best sounding cheap speakers I have ever owned. I was leary at first as I didn't like low model Klipsch. But these were fun... (no bass, but I was ok with that at the time)
I am curious to see if anyone in america comes up with a synergy or unity build that uses decent drivers. I am still considering playing with unity (I will have a pair of CD's by end of summer to play with for econowaves, too)... |
#664 | |
#665 | |
#666 |
Also some similarity to an AMT. Are the upper and lower ducts to the center of the M2 offset/isolated from each other or are truly open/in parallel?
Paul |
#667 |
I was happy with the synergy design with the clarion drivers, but being the kit was designed in Australia with odd drivers made it impossible for me to get it at that time. I was thinking about trying the pyle mids with the unity horn design just for fun, after my wood working skills improve a bit. The pyle mids are easy to get... But the 2" clarion seemed to solve some issues... Oh well...
P.S... I worked for BB for almost a decade. That place satiated my home/audio car bug when i was younger as I got cost on stuff. Made it easier to play around with stuff... I could own it for a while, then sell it when I wanted to try something else. Hey, if it was not for us selling even basic JBL, I would not know what EOS stood for Of all the years I worked for them, those were my favorite speakers by far... (I liked the advent laureattes as well).I still want to make a unity or synergy horn... need to improve my wood working skills first. I was bummed when the S3 horns were made with the orion mids. Too hard to get, especially for playing around. The pyle's look like they are cheap and easy to get still... |
#668 | |
I picked up some unused Visaton M10 drivers off of the bay as they looked interesting and have just tried them out on a 90 x 55 horn that I built. I haven't done anything special with them, just using two straight 18mm deep x 16mm diameter ports per driver they give a pretty usable frequency range (+/-3db) between around 400hz to 2khz. The only deviation to that is a 2db bump around 500hz, which I'd probably just crossover a little higher to bring it into line (rolling off a bit below 500hz). As for the drivers themselves I think they are quite nice little units, the square frame format means the cone extends nice and near to the edge making them easier to get close to the tweeter. Also because the cone angle is relatively shallow the air chamber in front is automatically small making them easily reach up to 2khz with little or no effort. I hope this helps. ![]() Paul. |
#669 |
I would love to see the measurements for the Visaton M10s. Since I'm still in Germany for a couple more months I've been thinking about picking some up for a future Synergy build (first want to make some AMT tweeters for the apex).
Is it the size of the horn or the FS of the M10 that is the primary cause the roll off below 500 Hz in your measurements? |
#670 |
Unfortunately I didn't save a plot with Visaton M10 drivers on (just have a few figures written down) and have moved on a bit with that horn with a number of other changes.
So any measurements I'd make now wouldn't be typical ones. As for the roll off below 400-500hz, The horn I played with isn't very large with only a 24" x 12" mouth so it may have a bit of an effect. However having said that when I tried similar midranges with a lower FS figure on the same horn they didn't roll off until around 300hz. So I suspect that it is indeed the FS which has the greater effect in this case. I hope this helps, Paul. |
| Bandpass Woofer/Midrange? | m@ | Multi-Way | 5 | 25th March 2006 02:10 AM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 05:06 AM |
