Suitable midrange cone, for bandpass mid in Unity horn.
Old 16th March 2012, 06:07 PM   #531
JLH is offline JLH  United States
JLH's Avatar
Here is the phase response of the Unity script Iíve been working on for the RDC3T-A. The spikes in the high frequency range are reflections coming off of something. Iíll figure that out later. Pretty pleased with the simulation results so far.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 16th March 2012, 06:18 PM   #532
John Sheerin is offline John Sheerin  United States
Thanks for the offer, but I just need to suck it up and make some horns. I've actually had a pair of LeCleac'h horns cut for several years now and just need to finish sanding them. I've been working on a cabinet for a JBL 2245 to sit one of them on top of, but I've got too many other projects going at the same time. Eventually I'd like to do another unity horn as well to take advantage of some of the better drivers everybody's finding here.
Old 16th March 2012, 07:02 PM   #533
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by JLH View Post
Since I couldn't get that Celestion 4", I went for the Misco RDC3T-A. It works damn well from what I've done with them so far. The best thing about them is that they were originally designed as a tweeter so once horn loaded they present a nearly resistive impedance. This makes it easier to use in a Synergy horn because you don't have to worry about its resonance screwing up the lower end frequency response. Its low end response is then purely controlled by the local area of expansion (i.e. local flare rate). I ordered a half case of them (30) and tested them all after breaking them in for 48 hours. Below are the overall average T/S parameters. The only way to come up with Vas was to use the sensitivity method with Smith & Larson Speaker Tester.
Fs = 1240Hz
Re = 7.76 ohms
Qes = 6.5631
Qms = 4.9345
Qts = 2.7557
Le = 0.4587 mH
Vas = 0.0559 L
Bl = 3.36
Cms = 3.36E-05
Rms = 0.77
Sd = 34.21 sq cm
My woofer tester wouldn't give me a proper measurement of the Goldwood GT-25, so I had to chop one up to figure out it's parameters. If you use my parameters in hornresp, be sure to add a back chamber, which will raise the FS and QTS to match the sealed back parameters.
Fs = 448Hz
Re = 7.19 ohms
Qes = 8.02
Qms = 8.51
Qts = 4.13(!)
Le = 0.38 mH
Vas = 0.06 L (guesstimate based on JLH's measurements of the similar Misco)
Sd = 39.59 sq cm[/QUOTE]
Old 17th March 2012, 01:06 AM   #534
winslow is offline winslow  United States
I'm making dust, just not wood dust...plenty of fiberglass and bondo dust though. 20 something years of custom car audio fabrication coming into play.
Gotta order another gallon of resin and some 8oz 2x2 twill fiberglass cloth...which is badassed since I can drape it over the mold in one piece and only need 2 layers to get the thickness I need. Two single piece layers giving me the thickness of about 10 layers of mat in a very easy and non messy lay up. Wet both pieces out together, cover the mold, work the bubbles out, and done...5 minutes.
Old 17th March 2012, 01:11 AM   #535
Runs off to see what John's filer does on the Miscos...
They are pretty cute little speakers...
Old 17th March 2012, 02:49 AM   #536
boris81 is offline boris81  United States
I can't get over how well that faux-axial horn sounds.
Old 17th March 2012, 04:30 AM   #537
Patrick, please let me send you a can of Partall Paste wax...killing me with the mold release stuff. Or you can have the rest of my can of Meguiars #8 mold release wax.
If you had some way to spray it, I would send you some of my Partall PVA mold release. Put that on top of the wax, and nothing is sticking.
Old 17th March 2012, 06:58 PM   #538
Default faux-axial Neo8?
What do you guys think about building a faux-axial waveguide for the BG Neo8?
The high sensitivity, low distortion and extended response make it a great candidate.
Old 18th March 2012, 12:10 AM   #539
US Patent number 7316290 might be of some interest for you.
Old 18th March 2012, 07:51 PM   #540
Attachment 272349
my thoughts here
Taming the NEO8 - DIYMA.com - Scientific Car Audio - Truth in Sound Quality
Suitable midrange cone, for bandpass mid in Unity horn.Hide this!Advertise here!
Bandpass Woofer/Midrange? m@ Multi-Way 5 25th March 2006 02:10 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
