#11 |
Puggie has a couple threads going on the same basic topic, so I'll cross post my previous cross post. DJK over on AA dug this guy up. No previoius exposure/experience, but the numbers look perfect, or at least better than anything I've seen previously if they're being honest. Looks like loudspeakersplus.com is the distributer in NA, although they aren't listed on the site.
http://www.paacoustic.com/Product_D...oductID=WN-520N The summary: 5.5" nominal frame 1.5" CCA coil 0.14mH 80W 173hz Fs 0.200 Qts 1.23L Vas 2mm overhang cloth edge paper cone carbonfiber/kevlar dustcap smooth on-axis to 4Khz |
#12 |
Thanks for the explaination. I just modeled my first 4th order bandpass enclosure in WINISD and I now understand that covering 5 octaves is pretty much impossible. I wanted to use my Aura monopole combined with the unity waveguide as the mid. Is it difficult to get a 2,000Hz+ low-pass with the unity? When I construct the waveguide, would I only need one throat from the (2-3) midrange ports (the throat where you have the BMS compression driver)?
Why do you take the FS of the driver instead of the FS of the enclosure? Trying to get a flat response with a bandpass enclosure is a daunting task. I know you are using passive crossovers but would I be fine using an active crossover with 7 adjustable points of eqing? |
#13 |
Doug,
Nice catch! I just got off the phone with Loudspeakers Plus. I'm going to find out what quantity is needed to get these over here stateside. If I have to buy 20 or 50 and sell the rest, I'll do it. I'll let everyone know how soon we can get it. As I see it, the problem with the Unity midrange is that it's hard to find a small woofer with a huuuuge motor. I'm kind of a noob when it comes to motor design; but I think this is inherent to small woofers. Basically, if you put a big ferrite motor on tiny driver, the flux isn't concentrated into the gap. Of course it's not such a problem with large woofers, because the gap is much larger. This could explain why the JBL GTI400, the Aurasound Whisper, and the P-Audio Winner are good candidates; they're all neo. :: PB :: |
#14 | |
:: PB :: |
#15 | |
To say that big ceramic magnets on a small driver cannot be made to keep the flux concentrated in the gap is fiction the motot structure and magnet is not to blame. Flux is flux no matter if the source is a ceramic or a neo magnet. How much flux from the magnet that you can concenrate into the gap is dependant upon the size of the top plate and the geometry of the motor structure. Once you saturate the top plate and or the pole piece then you have hit you max flux. The answer is more and better quality iron for you motor parts. I think it is just that simple. Regards Moray James.
moray james |
#16 | |
Here is the pdf: http://www.aurasound.com/pdf/ntl25-354-4a.pdf So are drivers with large motors good, bad, or indifferent for this application. I am still confussed as to what specs the midrange enclosures are suppose to have. Awesome! I got a value of 491Hz with the Audax HM100C0 drivers that I am currently using. I am not sure if the 54Hz Fs matters though. The motor on this thing is freakishly large too. I just modeled it in WINISD and it has a super flat response compaired to the Vifa that I just modeled. Vf = 0.6L, Vr = 0.6L, Tuning Freq. = 183.67Hz. |
#17 |
Sorry for the slow learning curve... I guess my Audax midrange drivers are only covering 1 octave because of the low FS.
#18 | ||
Do you know what 75% of them have in common? You guessed it, neo motors. |
#19 |
the advantage that a neo will have is strictly physical they are smaller for a given strength. If you have ever played with any of the small full range driver that Fostex make the magnet is only marginally smaller than the cutout for the driver. That simply means that if you wanted more flux with a ceramic you would have to start stacking magnet slugs. So yes neo magnets would be easier to work with and lighter. That does not mean that they are better in terms of the flux they provide. They simply present a way to shrink your physical magnet size as compared to ceramics. You would be surprised to see what kind of increases in flux density are possible with top quality ceramic slugs (there are a number of grades available) when combined wit computer designed geometries top quality iron and super tight tolerences in build/ Today neo magnets are available at better prices than ever before so yes they are worth taking advantage of. This will result in a more reliable driver as big motors on the back of tiny frames have a habbit of being easily knocked off due to the small area availabe to secure the magnet.
Ok so you have found a dozen candidates that's good and I look forward to seeing the list. This is still a tiny number in the grand sceme of things. This is not your normal run of the mill mid driver. As you can see I have not disagreed that neo is nice for all the stated reasons I only wanted to point out that they do not make any better flux than would a ceramic magnet. No magic. Regards Moray James.
moray james |
#20 | |
I like GM's analogy on carsound, speakers are similar to cars, fast ones are generally expensive and I guess fast small ones as standard are quite rare!! |
| Bandpass Woofer/Midrange? | m@ | Multi-Way | 5 | 25th March 2006 03:10 AM |
| looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P | SkinnyBoy | Multi-Way | 24 | 13th February 2004 06:06 AM |
| Page generated in 0.09595 seconds (73.16% PHP - 26.84% MySQL) with 11 queries |
