Suitable midrange cone, for bandpass mid in Unity horn.
Old 26th October 2013, 06:54 AM   #1351
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by Sheldon View Post
Just the Aura's or did you listen to the full system?
sheldon
Oddly enough, I've never heard a Synergy Horn.
I think I need to remedy that - just noticed that there's a local company that rents them:
Audio Equipment | Nexo Line Array Speakers, EV Speakers, etc. | Special Event Audio Services
Thought I'd post that, since it's in our back yard
Old 26th October 2013, 11:48 PM   #1352
peteleoni is offline peteleoni  United States
Well now. This is going to be illuminating (-:
I am The Audio Infidel..... I don't even tolerate my own BS.
Old 27th October 2013, 01:34 AM   #1353
JLH is offline JLH  United States
JLH's Avatar
Once you hear a properly set up Synergy there is no going back. I recommend the SH46 or SM60F. The Synergy's intelligibility smokes everything I've ever heard. Because they are PA speakers, they can be a little hot in the high frequencies. I recommend they be EQed down a little bit in the highs. That's why I stressed "properly" set up part at the beginning.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 31st October 2013, 02:00 AM   #1354
Beau is offline Beau
Another mid alternative?
3" Paper Cone Sealed Back Midrange 8 Ohm 289-001
Old 31st October 2013, 10:58 AM   #1355
JLH's Avatar
Originally Posted by Beau View Post
Possible. The one thing you want to find out is what the suspension compliance is. If the suspension compliance is too low (too stiff), then it can be difficult to get the mid to turn off after the 1/4 wave cancellation notch. The Misco RDC3T-A has just enough suspension compliance to work, anything less compliant would makes things very difficult for you. The suspension compliance of the RDC3T-A is about 3.3E-05m/N
Old 31st October 2013, 11:13 AM   #1356
kees52 is offline kees52  Netherlands
the SM60F looks good for home use, simple build.
Old 31st October 2013, 02:15 PM   #1357
HIPCHECK is offline HIPCHECK  United States
HIPCHECK's Avatar
FS 1000HZ
I know we are targeting a crossover around 1-2K to compression driver in most designs, what freq would a driver like this cover in a synergy/unity design. Most mids I have seen have a 400-700Hz FS. I do understand some that the horn will "load" the driver some and also effects the freq?
Steve
If a inch of duct tape will fix it, 3 feet should fix it for life!!!!
Old 31st October 2013, 09:09 PM   #1358
JLH's Avatar
Originally Posted by HIPCHECK View Post
FS 1000HZ
Steve
The local area flare rate plays the biggest role in how low the mids will play. Mids with higher compliance combined with very pronounced resonance can override this to a degree. Mids with lower compliance and well behaved resonance pretty much take on whatever the local flare rate is. This is covered in the Synergy patent.
Old 2nd November 2013, 01:29 AM   #1359
JLH's Avatar
Parts Express is replacing the defective DE120 compression driver no questions asked. Great customer service. However, they are on back order and will take about two weeks to come in. One thing to be aware of is the mounting screw size on the data sheet is wrong. The mounting screws are M5 and not M6 as shown on the data sheet. Funny enough, the mechanical drawing file has the screws correctly marked as M5. Time to reorder new screws.
Old 5th November 2013, 04:21 AM   #1360
Nuther one.
The Madisound Speaker Store
Suitable midrange cone, for bandpass mid in Unity horn.Hide this!Advertise here!
Bandpass Woofer/Midrange? m@ Multi-Way 5 25th March 2006 02:10 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
