Suitable midrange cone, for bandpass mid in Unity horn.
Old 19th October 2013, 11:44 PM   #1341
cookiemonster77 is offline cookiemonster77  Norway
Originally Posted by weltersys View Post
The extra thickness of the adapter is trouble for the mid driver's offset entry location and depth.
Other than that detail, no problem .
Good point! Nice thing is, nothing is written in stone here. Wonīt send anything for printing before I have a full model. I am just waiting for somebody in the thread to agree on the perfect midrange driver.
The normal distance from CD to straight horn is 51.5mm, plus the 27mm (rough guess from drawings i have seen of the DE250), and that would equate to a quarter-wave frequency of 1100. Should be high enough for this not to become an issue, right, since the cancellation will be somewhere between quarter-wave and half-wave?
I canīt seem to figure out a way to attach the adapter to the wooden section without gluing it forever though. Any ideas?
Last edited by cookiemonster77; 19th October 2013 at 11:56 PM. Reason: Forgot to include path length in CD
Old 20th October 2013, 01:46 PM   #1342
kenpeter is offline kenpeter  United States
Neodymium Countersunk Ring Magnet 1/2" x 1/8" 320-022
Old 21st October 2013, 09:31 AM   #1343
Hrmmf is offline Hrmmf  Denmark
Default Faital HF146 Parameters
Hi Guys.
So, while I'm waiting for the package from Faital to arrive, I got them to advance some T/S parameters along with (what I think is) the acoustic path length.
From Faital:
Please find here the following information:
Re=5.5 Ohm
BxL= 9 Tm
Data got by measuring impedance curve:
Qes= 1
Qms= 7.5
fs= 530 Hz
Distance from the exit phase plug driver in the mouth: 17mm
Distance from membrane-mouthed driver 36.5mm"
Do I interpret the 36.5mm as being the acoustic path length?
/Thomas
Old 23rd October 2013, 07:16 AM   #1344
Default Coverage angle
Hi guys.
I'm trying to figure out which coverage angle will be optimum for my listening room.
How do you guys determine the best coverage angle?
I've made a sketch of my living room with a pair of 90 degree horizontal dispersion Synergies'
Should I perhaps choose a narrower horizontal coverage angle (80 degrees) toeing slightly outward, bringing me closer to the forward axis?
/Thomas
Old 23rd October 2013, 01:42 PM   #1345
nc535 is offline nc535
That is a fine point. Best is likely a matter of taste and experience guiding tradeoffs. Sitting too far back from the crossing of the axes of the horns shouldn't be a problem for the centrally seated listener but might be for someone seated to the side . 90 vs 80 degrees is 5 degrees difference in the horn wall half angle. tan(5) is 0.3 m/3.5m. This might mean the sweet spot increases by that much on each side or it may mean the listeners on the side must be at least .3m from the walls or both! Problem is the 80 degree horn will be significantly deeper...
Old 23rd October 2013, 06:58 PM   #1346
Thanks nc!
Since I'm the only "real" audiophile in the family probably means that I won't have to fight for the sweet spot
Horn depth is not an issue, since I'm the one wearing the pants in this family
I'm still waiting the Faital package to arrive (Faital HF-146 + a pair of 8FE200)
The acoustic path length of the HF-146 pretty much determines the coverage angle, which will be somewhere between 80 and 90 degrees.
/Thomas
Old 23rd October 2013, 07:43 PM   #1347
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Originally Posted by Hrmmf View Post
Hi guys.
/Thomas
IMHO the most compelling reason to narrow the angle is that it raises the output level in the octave from 1-2khz. And that simplifies getting the midranges to 'meet' the tweeter.
I documentd that with some illustrations and hornresp sims a few months back on this forum. Can't recall if it was this thread.
Old 24th October 2013, 12:12 AM   #1348
weltersys is offline weltersys  United States
weltersys's Avatar
Thomas,
I don't get that statement, you could make the horn any beamwidth you want, though a 5 degree horn with pattern control down to 400 Hz might still be too long even for your pants .
Realistically, anything from 40 to 100 degrees would be no problem.
Old 24th October 2013, 06:11 AM   #1349
Thank you for your input, John-Patrick!
Since I'm doing a 2-way (SH-95 style) I will be aiming at a crossover in the region 700-800Hz.
/Thomas
Old 24th October 2013, 06:20 AM   #1350
Thomas,
By narrowing the coverage angle, I'll have to push the mids further down the horn in relation to the tap-in area. This may sacrifice the half-wave criteria in relation to the CD, i.e: if the CD's acoustic path length is very long, this only leaves little distance for the mids. By choosing a wider angle enables you to push the mids closer to the CD!
...you could make the horn any beamwidth you want, though a 5 degree horn with pattern control down to 400 Hz might still be too long even for your pants
You're right, and even our garden can't accomodate a 50m horn with 295m^2 mouth
/Thomas
Suitable midrange cone, for bandpass mid in Unity horn.Hide this!Advertise here!
Bandpass Woofer/Midrange? m@ Multi-Way 5 25th March 2006 02:10 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
