Suitable midrange cone, for bandpass mid in Unity horn.
Old 20th September 2013, 06:13 AM   #1111
Hrmmf is offline Hrmmf  Denmark
Originally Posted by Beau View Post
Thomas you, Hrmmf
Aha!
Well, I actually prefer closed back, cloth surround, paper mids!
Is base my preferences on something JLH wrote about "ideal" midrange characteristics somewhere along this very active and ongoing Synergy thread.
Also, there must be a specific reason to why Danley prefers these types of mids his designs.
/Thomas
Old 20th September 2013, 06:18 AM   #1112
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I will have to consider a 2" CD
rolled off top is ok for bass guitar
but the higher price is not
though the bigger CD might have other advantages
just now noticed a 1.4" BMS 4554 at 110EUR (and cheap shipping)
funny 1.4" CD, because the cone is the same used in 1" drivers (1.75"/44mm)
recommended 1khz xo point
sometimes we know very little, and sometimes we know too much
Old 20th September 2013, 07:22 AM   #1113
Originally Posted by JLH View Post
Every choice has a cause and effect. Also note that while I choose to simplify the script by using round ports, in real life I use slotted ports. I make the ports' width and length follow the Golden Ratio. So in case of that Visaton M10 script, the ports are approximately 1.55cm X 2.5cm and not really 2.2cm diameter
John, are kepping the width (1.55cm) as i fixed value, solving for x as the length variable:
1.55/x = 0.62 (ratio) -> x = 2.5 ?
Found it!
Golden Ratio
- Still, how do you decide on the width, by hunch ?
/Thomas
Old 20th September 2013, 12:55 PM   #1114
Originally Posted by Hrmmf View Post
Found it!
Golden Ratio
with the golden ratio ? ... estimating works fine
Old 20th September 2013, 01:08 PM   #1115
- Yes, the Golden ratio!
I mean you have to decide on an initial value, in this case I guess it's the width (1.55cm)
solving: x/1.55 = 1.618 -> x = 2.5
/Thomas
Old 20th September 2013, 01:21 PM   #1116
the important thing is that the hole is accurate area
and I suppose all should be equal size
if you also happen to believe in the blessings of golden ratio, that is good enough if estimated
golden ratio is known and proven to please the eye, and give balance in what you see
but I don't know if any other effects have ever been proven
but if designing asymmetric horn, I could still be tempted to use golden ratio between height and width
and should fit the golden ratio rule all the way from mid's pass holes to horn mouth exit
horn length might be a different matter, and depends on horn type
Old 20th September 2013, 01:39 PM   #1117
JLH is offline JLH  United States
JLH's Avatar
/Thomas
I use the Goal Seek function in Excel to find it for me. I have a cell that has the formula something like =A*B. Then I have a cell with formula =A*0.618. The third cell does not have a formula, just an arbitrary number. I then go to the DATA tab in Excel. I highlight the cell with the formula of =A*B. I then click the WHAT IF ANALYSIS. I have Excel solve for the area I want by altering the other two cells.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 20th September 2013, 01:41 PM   #1118
Fane 6" midrange
Old 20th September 2013, 01:57 PM   #1119
JLH's Avatar
Correct, getting close is good enough. The Golden Ratio helps prevent standing waves and reduces constructive reflections. Bruce Edgar has been a long time supporter of using a 1:1.6 mouth ratio. I tend to agree with him. I use a several naturally occurring numbers when I design horns. My results have always been better following this. I use the Fibonacci sequence, Prime numbers, Pi, and of course Phi. A lot of times when I'm doing calculations these numbers naturally will pop up. To me this is form telling how it wants to function. Not to say that I depend on these numbers as some kind of voodoo magic design tool. I still approach everything with a scientific mind, but don't get surprised when I see these numbers show up in my calculations.
Old 20th September 2013, 02:11 PM   #1120
JLH's Avatar
Fane 6" midrange
The design challenges you run into with larger cone mids is it requires much larger port holes to reduce the air velocities. This in turn pushes the crossover point lower, which then forces you to use a larger compression driver, which results in a larger throat area and cross sectional mid tap in point.....etc. And it goes on and on.
The practical cutoff for mid size is about 5.25". You might be about to get away with a 6" if you use a 1.4" or 2" compression driver that can work down to about 600Hz - 700Hz. I had a design for using a pair of Eminence Beta-6A mids with Faital HF146 compression drivers. I never took it anywhere because dropping $500 just on the compression drivers is too much for my blood.
Suitable midrange cone, for bandpass mid in Unity horn.Hide this!Advertise here!
Bandpass Woofer/Midrange? m@ Multi-Way 5 25th March 2006 02:10 AM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
