BBBIB Bigger Badder BIB Speaker - Page 20 - diyAudio
Old 6th April 2007, 09:41 PM   #191
jbush is offline jbush  United States
WOW, these things are huge!!! Looking at them on the monitor and on paper they look pretty big, but I actually measured where they would go in the room and there wasn't much of the room left. I might have to try a slightly smaller BIB.
Jeremiah
Old 6th April 2007, 10:04 PM   #192
Pano is offline Pano  United States
Pano's Avatar
Can't you just put them flat against the wall? That way they sort of "become" the wall.
Good to see this thread active again.
Take the Speaker Voltage Test!
Old 7th April 2007, 06:14 AM   #193
GM is offline GM  United States
GM's Avatar
Greets!
That's the plan!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 7th April 2007, 07:26 AM   #194
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
OK, so the Pioneers in the sketch were already on the big size for the driver. But I forgot to re-ask my question: Does the tapped woofer necessarily require a larger cabinet? My understanding is the one in the sketch is so oversized already that the tapped woofer is accomodatred for that reason., but how about the previous, smaller pioneer(universal ) cabinet?
Jeremiah- come on man!! This is your chance- You'll be the FIRST, once you're married good luck building them! You can put the driver in the sidewall and turn them 90 degrees as just mentioned. Also, you can play with the proportions a bit and make them flatter like the monoliths... They don't HAVE to be 1.414:1 apparently.
"The geek shall inherit the earth"
2016 S.F. Burning Amp Festival To Be Nov. 13
Burning Amp thread here on diyAudio [/B]
Old 7th April 2007, 04:27 PM   #195
Scottmoose's Avatar
Well, adding a second driver parallel wired means Vas doubles, so more Vb is required as compared to a cabinet for a single unit. The extent to which it increases will likely depend on the driver selected. Doubling the Vb over the single unit will probably be safest however.
"'That'll do", comes the cry of the perfectionist down the ages.' James May -The Reassembler
www.wodendesign.com Community sites www.frugal-horn.com http://frugal-phile.com/
Old 30th July 2007, 10:23 PM   #196
EEatKSU is offline EEatKSU  United States
Smile Anyone remember the BBBIB's? I built a pair.
Heres some pics of my build of BIB's for the Eminence 12LTA driver and a Fostex FT17 tweet. It takes 5 sheets of ply for the two enclosures, 6'3"x20"x30" rough dimensions.
On to the pics
These speakers completely utterly dominate, with the space they take up and the low end they pump out. They get painful loud with UNDER 100 watts, I'm powering them with an ART SLA-1 amp and I can't turn it up all the way, I can't take it. The low end on these is just unreal, feel it in the chest, in the floor, in the walls, its just nuts.
I don't think they turned out to bad for the build time being roughly 24hrs (that includes sleep)
Old 30th July 2007, 10:36 PM   #197
GM's Avatar
Kewl!
Glad to see someone finally built some. What's your opinion of their performance beyond the room shaking bass and decent efficiency?
Old 30th July 2007, 11:26 PM   #198
I'm glad someone made these. I have been sitting on a pair of Beta 12-LTAs for a couple months now. Been trying to decide if I want to throw the non-whizzer-coned Beta 12s in for some of the tapped horn goodness that Scottmoose brought up in the original thread.
Those look great, but I bet they will eat that tv if you leave them alone in the room with it.
Old 31st July 2007, 12:11 AM   #199
GM's Avatar
Originally posted by jbush
........I bet they will eat that tv if you leave them alone in the room with it.
This reminds me of the floor loaded 15" woofer pipe corner horns I did back in the Stone Ages, I had a 25" vacuum tube TV and kept vibrating them loose playing a special effects RTR tape that had significant output to 30 Hz, a really low F back then. At the time we were living in the downstairs apt. at the far end of a long building and I would go home for lunch to 'experience' them since I couldn't do it any other time of week. Well, one day an insurance adjuster shows up and tells me I'm going to have to reimburse them for replacing some China, pictures, and knick-knacks that had hit the floor due to what the elderly dweller in the upstairs apt. at the other end of the building claimed was due to repeated earthquakes! Thankfully, this was the extent of my liability, though there probably were other neighbors with similar problems. After that, I limited myself to higher cut-off vinyl until I got a house of my own way out in the extreme edge of the suburbs. That old lady really got tired of the ~17 min. version of Iron butterfly's 'In-A-Gadda-Da-Vida' cranked up to ~live levels though! Not to mention Pink Floyd's early stuff, especially 'Careful with that axe, Eugene'. That scream is blood curdling at high SPL.
Gees, those were the days, young, carefree, socially irresponsible .......... so now I 'bite my lip' and 'grit my teeth' when the local kids crank up their boombox cars to distortion levels I never dreamed possible in my youth.
Old 31st July 2007, 01:41 AM   #200
These are currently a what the hell why not build it setup in the upstairs part of my house.
The first words my roommates said was "Ah, ****, what the hell is this?" My roommate that listens to techno likes these speakers even more than I do I believe...
I'm currently a Junior in Electrical Engineering here at Kansas State University and tend to build rather ridiculous setups for their locations. *think noise complaints in the dorm, from 2 floors away...*
This is not my main setup here in my house, I just moved this in today to play with it. The main purpose of this is to provide audio for a dance team entry in a parade, and beyond that, I have no clue.
Someone could easily use these for everyday listening, with very low power they are docile and well behaved, but its like Dr. Jekyll & Mr. Hyde, start feeding them power and they become downright ridiculous. I wouldn't quite describe them as a HiFi unit, but I could easily have them as my everyday speakers if I had the extra room to play with.
While I'm at it here are some photos of my other setups that I've had (and currently use).
This is in my basement *The BIB's are upstairs*, Magnepan MGIIB's and various pro audio gear. The substage is a single sealed Mach5Audio MAW 15, soon to be a pair of them once I get the second box built.
For a college house setup, I don't think it is to bad.
Here is some of my previous follies into the audio world in a dorm room.
MTM setup using Dayton Reference 7" and Morel MDT29
Same Dayton Reference's, just ported to 40hz....
My freshman year I had a pair of Fostex FE103's in their reccomended BLH design that I made out of walnut.
Copyright ©1999-2017 diyAudio
