I'm in the process of building a prototype of a horn and
I need to split the pathway in two immediately after a fold as pictured below. My question is, will this divide the pressure/wave flow into equal parts, or will the fold itself create an unequal flow? It seems that more would flow via the upward route, like water flowing through a bend in a river, but I've never taken a fluid dynamics class to know the physics involved.
Everyone has a photographic memory. It's just that most are out of film. |
#2 |
For low frequencies, ie when the wavelength is much larger than the diameter of the ducts, the flow will be divided in two equal parts, provided that the two "mouth" channels are identical all the way to the surrounding air.
Note: Typically it is wrong to think of the sound waves in a duct as a stream of air; a stream of air assumes turbulent flow, and that is not the case in loudspeakers, unless they are overloaded. |
| PSU Question...Full Wave Bridge | zxx123 | Tubes / Valves | 3 | 25th January 2008 07:04 PM |
| 1/4 wave enclosure question. | EEatKSU | Multi-Way | 5 | 28th September 2007 03:00 PM |
| Sine wave - Square & Triangle wave generator using Transistors / OP-Amps | lineup | Solid State | 20 | 9th October 2006 12:15 AM |
| Page generated in 0.06015 seconds (70.74% PHP - 29.26% MySQL) with 10 queries |
