Old 10th October 2006, 01:21 PM   #1
Default How do you "edge seal" your MDF enclosures?
I've heard of people using wood glue, but that seems to be alot more of a hassle than it needs to be. Does anybody have any tips? I try to do it with watered-down wood filler, which seems to work ok, but I don't know if that's the difinitive way to do it or not.
Old 10th October 2006, 01:27 PM   #2
Cloth Ears's Avatar
Do you mean sealing the cut edge of the MDF where it's exposed to the 'outside world'? Or sealing the edges where they join to other pieces of MDF?
For the first, I veneer, using thick veneer and glue so there's nothing exposed.
For the second, I don't have any gaps to seal.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 10th October 2006, 01:27 PM   #3
jackinnj's Avatar
you need a filler which will shrink and expand at the same rate as the MDF -- apply a good sanding sealer, dry per instructions, wet sand, apply another coat, then finish. Zinser works reasonable well.
You can also coat the edges with bondo diluted in a polar organic solvent.
Old 10th October 2006, 01:47 PM   #4
I have not tried this before, but the magazine - The Family Handyman - had an article about using (I beleive watered down) drywall compound to do this...
Good luck,
Mark
Old 10th October 2006, 01:56 PM   #5
jackinnj's Avatar
Good luck,
Mark
that stuff will fissure -- cracks --
Old 10th October 2006, 02:08 PM   #6
GM is offline GM  United States
GM's Avatar
Greets!
Drywall joint compound or spackling paste is my filler of choice when it's going to be painted or veneered. For more durability, two part epoxy. In some cases, depending on the finish you want to achieve, a product like gesso is applied and then sanded smooth to fill and seal in the MDF: http://en.wikipedia.org/wiki/Gesso It's used both as sealer and a primer. In other cases a thinned wash coat or two of Shellac or similar. Glue sizing (equal parts white glue and water) can also be used for toners, stains, shading stains, glazes, sealers.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th October 2006, 10:06 PM   #7
AIA is offline AIA  United States
The process is called "glue sizing." Dilute yellow PVA wood glue with tap water (or spike tap water with yellow glue) until it is the consistancy of chicken noodle soup without the chicken and noodles. Brush the mixutre on and let dry. It will seal the very porous edge of MDF so that the edge will take paint the same way the face will take paint.
Old 12th October 2006, 10:54 PM   #8
pinkmouse's Avatar
I'll go with Jack, Sanding sealer is the stuff.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 12th October 2006, 11:17 PM   #9
If you mean an exposed edge, I'm in the veneer camp. Iron on, precut to width type is handy.
For a joint; the new polyurethane glues, of which Gorilla is best known, expand as they cure, ensuring an airtight seam.
Old 13th October 2006, 12:29 AM   #10
Cloth Ears's Avatar
That's what I use for edge joints. So I never need to worry about any extra sealing measures. You gotta have pretty good clamps, though, as it's fairly agressive in it's expansion. I use the Selleys version of the same thing.
Jont.
"Thor" SubWoofer Enclosures (2) ppfred Swap Meet 0 12th March 2009 02:34 PM
"Karlsonology" (Karlson enclosures/technique) what's happenin' ? freddi Multi-Way 45 29th January 2008 09:06 PM
What do you use to seal subwoofer enclosures? simon5 Subwoofers 23 14th January 2005 04:01 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
Page generated in 0.10044 seconds (78.28% PHP - 21.72% MySQL) with 10 queries
