How do you "edge seal" your MDF enclosures?
Old 10th October 2007, 01:10 AM   #21
Cloth Ears is offline Cloth Ears  Australia
Cloth Ears's Avatar
Originally posted by Brett
Which of the Selleys products do you use?
After reading John's thread (post #20) I'm not so sure I'll continue doing this without prepping the MDF first. And as this stuff works better with a small amount of moisture (I generally wipe one surface with a dmap cloth before applying it) I'm not sure that I'll continue using it with speaker joints.
That said, all I can remember at the moment is that it's got a 'mostly' green label, and that iut's been sitting in the dark cupboard for about 4 months, unused and unloved. I'll see if I remember to look at it and post when I get home...
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 10th October 2007, 02:24 AM   #22
MJL21193 is offline MJL21193  Canada
MJL21193's Avatar
Hi Jon,
A small amount of moisture applied to the surface prior to the urethane glue shouldn't be too much of a problem. My reference in that thread is for the kind of finish that Ant (Shinobiwan) does and Gordan (Sploo) is doing - the high gloss piano black.
Given an adequate time to dry out, it should be fine.
Old 10th October 2007, 02:38 AM   #23
Cloth Ears's Avatar
Agreed. My prep has previously not involved sealing the inside of the cabinets before construction. As they're invariably sealed boxes I haven't worried too much - but as the bones get older (I think I've got 3 years on you) the number of boxes I intend to build gets smaller. So I want to do them right.
Jont.
How do you "edge seal" your MDF enclosures?Hide this!Advertise here!
"Thor" SubWoofer Enclosures (2) ppfred Swap Meet 0 12th March 2009 02:34 PM
"Karlsonology" (Karlson enclosures/technique) what's happenin' ? freddi Multi-Way 45 29th January 2008 09:06 PM
What do you use to seal subwoofer enclosures? simon5 Subwoofers 23 14th January 2005 04:01 PM
Membrane to limit "unloading" in ported-type enclosures? Datoyminaytah Multi-Way 6 18th August 2004 05:36 PM
Need help using "Edge" to design Baffle Step Correction Circuit please. G Multi-Way 5 3rd July 2004 10:49 PM
Copyright ©1999-2017 diyAudio
