How to DIY a wooden multicell Horn How to DIY a wooden multicell Horn - Page 2 - diyAudio
Old 15th October 2006, 02:02 PM   #11
bear is offline bear
expert in tautology
bear's Avatar
Just do some research on the basic design.
They can be built.
Well, anything can be built.
The construction can follow along the lines of the basic Altec/WE multicells. Of which this is a copy.
A problem will be at the area near the throat. The wood has a relatively large cross-sectional area (thickness) - which means that there will be reflections where the cells are combined, unless you do some very fancy wood working.
Also, a major issue will be the damping of the wood walls. The sound pressures in the horn itself are high. Damping is needed. Some of the metal horns were encased and potted in "tar" to make them stiff and damped, to solve this problem...
I'd say that to do a credible job in wood, you'd probably put in 100 hours in a well equiped wood shop... but they'd look good!
Myself, for home use I'd prefer a lower frequency cutoff single cell horn, probably a Tractrix...
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 1st October 2008, 08:32 PM   #12
stefanolo is offline stefanolo  Sweden
A forum colleague, Petter, on Hififorum.nu in Sweden is just about to finish a very nice pair of multicell horns. If you can get some-one translate for you, you could follow his work. Look at the pics, they're amazing.
http://www.hififorum.nu/forum/topic.asp?TOPIC_ID=67420
/stefan
How to DIY a wooden multicell HornHide this!Advertise here!
The construction of a multicell horn Petter Persson Multi-Way 232 18th May 2017 02:26 PM
Fostex Wooden Horn H400 and D1400 Driver Lindell Multi-Way 6 20th March 2009 02:21 PM
Wooden Enclosures Prt 2 pjpoes Solid State 17 28th March 2005 02:45 PM
Copyright ©1999-2017 diyAudio
