Old 9th October 2006, 01:47 PM   #1
Default passive line level Crossovers pllxo
I would like to make 12db per oct xovers (passive line level) according to this website. I'm having trouble picking starting values. Could someone help me make sense of this?
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
This is for a car system and I need a xover for about 3.1 khz.
My Head Unit boasts a pre-out of 4v/100k ohm (Pioneer deh-p7500mp)
My amp (aura 2300) claims an input impedance of 14k.
do I just arbitrarily pick a starting value or are these numbers relevant?
Old 9th October 2006, 02:42 PM   #2
Rudolf is online now Rudolf  Germany
Rudolf's Avatar
Default Re: passive line level Crossovers pllxo
Obviously your pre-out impedance should read 100 ohm instead of your stated 100k ohm. If that is true, you might start with 0,5-1kOhm for R1.
www.dipolplus.de
Old 9th October 2006, 04:10 PM   #3
R1 needs to be 1.5 K (~ R2/10), R2 = 14K (in your power amplifier).
/sreten.
Old 10th October 2006, 01:42 PM   #4
Thank you for the help; That makes sense to me. I didn't expect to see that impedance from my amp.
If I want a xover freq of 3.1 khz for the lowpass I came up with
c1= 3.42 uf
c2= .342 uf
I'm guessing that anything between 2 and 5 volts would be acceptable voltage for the caps. Would I use standard audio crossover capacitors (non-polar)?
If I'm missing something in my values please let me know. How close will this get me to the target frequency? Are these pretty accurate crossovers?
Geoff
Old 11th October 2006, 08:57 AM   #5
with R1 = 1.5khz and 3.1khz c/o, C1 = 34.2nF nearest = 33nF.
So your values are 33nF and 3.3nF, use any film capacitors.
/sreten.
help with passive line level crossover PLLXO for 33K impedance amps Daveis Analog Line Level 1 14th December 2008 08:12 PM
Line-level passive crossovers vdi_nenna Multi-Way 3 15th June 2005 11:39 PM
Passive Line Level Crossovers and Alephs (from a Neophyte) GeorgeBoles Pass Labs 8 27th October 2004 05:49 PM
Passive Line Level Crossovers GeorgeBoles Pass Labs 6 20th September 2004 10:49 PM
Page generated in 0.07511 seconds (75.84% PHP - 24.16% MySQL) with 10 queries
