I found some cheap parts for monitors, after some more research im going to try to build some. Im going to start out with a basic pair im trying to spend a total of $40-50 on parts not including cabinets. Then if I can make a descent pair in a reasonable amount of time, ill try to make a higher quality version. So eventualy these will end up being refrence monitors.
Im still trying to get a flat response should I go 50-20 or 50-22? would 70-20 matter? back to reading up on this. Is there any way of making these active monitors ? For each speaker I need sub,tweeter,crossover,port,terminal ? If I use two tweeters to make it 3way will that affect its ability to be flat? do i need a lpad? Whats the difference in tweeters dome,ribbon,cone,metal? example PYLE PRO 6-1/2 70-9,000 PIONEER 1" SOFT DOME 3,000-20,000 5k crossover this should sound ok? right? its 70-20k 28 bucks heres some of the parts im looking at, wich do you think will work best? subs 8.45 pyramid wx65 6 1/2'' 70-3500 11.70 GOLDWOOD GW-206 6 1/2'' 60-3000 14.25 PYRAMID W64 6 1/2" 60-5000 12.88 GOLDWOOD GW-S650 7" 35-5000 16.50 GOLDWOOD GW-6028 6-1/2 55-3,000 15.65 DAYTON PA165-8 6" 80-5,000 Hz 15.50 PYLE PRO PDMW6 6-1/2 70-9,000 Hz tweeters 6.14 AUDAX HY014R1 TITANIUM 1/2'' 4000-19 4.60 DAYTON ND20FA-6 3/4" NEODYMIUM DOME 3,500-25 4.93 TANG BAND 13-1264SA 1/2" TEXTILE 3,000-20 6.95 GOLDWOOD GT-322 1" TITANIUM DOME 3,500-20 12.90 PIONEER FBDE75-52F 1" SOFT DOME 3,000-20 2.30 GOLDWOOD GT-302/S 2-3/8" MYLAR DOME 4,000-19 .25 ONKYO 3/8" MYLAR DOME 6,000-20 11.00 PYRAMID TW22M NEODYMIUM silk dome 1" 2,000-20 9.88 1-3/4" NEODYMIUM TWEETER PAIR 3,000-20 |
| PC Monitors | huguini | Class D | 3 | 9th April 2006 09:56 PM |
| Page generated in 0.06589 seconds (66.91% PHP - 33.09% MySQL) with 10 queries |
