Old 8th October 2006, 03:06 AM   #1
Default Behringer CX2310 for Dayton/Vifa at 2350 KHz ???
Hi Folks
I'am in the process of moving a pair of ViFa/Dayton 2-way tower speakers from main to surround speakers.
Of course this goes with building a new pair of front speakers, potentially with a gain in quality. After being around a lot with different types of ideas, I'm wondering if going to bi-amping using the same driver configuration will be the best solution (it will maintain homogeneity between front and surround speakers - which sounds the best option).
My speakers are buit with a dayton DC28F as tweeter and Vifa P17WJ as woofer from a parts-express design (http://www.partsexpress.com/projectshowcase/vd/vd.htm), in a 22 litters box. The crossover frequency is at 2350 Khz.
The question is: will I have appreciable gains if i use an active crossover (such as the Behringer CX2310) to drive this kit ?
Thanks.
Old 9th October 2006, 05:16 PM   #2
Paul W is offline Paul W  United States
Paul W's Avatar
The CX2310 will deliver "textbook" crossover slopes so it could easily be a step backward from a purpose-specific passive crossover. The designer of the passive crossover likely compensated for baffle step, imperfect driver response, etc etc...things a stock 2310 cannot do.
With far more flexibility than the 2310, the DCX2496 could yield better performance.
FS: Behringer CX2310 two-way active crossover nl Swap Meet 1 10th June 2009 02:06 PM
Behringer ep1500 and cx2310 Beau Swap Meet 1 28th April 2009 10:59 AM
Behringer DCX2496 and CX2310 Thims Swap Meet 1 2nd March 2009 09:30 AM
Behringer CX2310 Schematic jbanneck Multi-Way 0 27th December 2006 11:29 PM
Behringer CX2310 for my line arrays? mazeroth Multi-Way 17 27th January 2005 07:20 AM
Page generated in 0.06344 seconds (67.16% PHP - 32.84% MySQL) with 11 queries
