Old 6th October 2006, 11:49 AM   #1
Default Please explain attenuation?
How do u determine the Negative attenuation of your tweeter (4ohm) in a 3 way system?
Old 6th October 2006, 11:12 PM   #2
Speakerholic
Cal Weldon's Avatar
Are you asking how much attenuation is in your XO?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 7th October 2006, 12:31 AM   #3
Hi Cal. what it is, I'm building a 3 way project and my bass and Tweeter are both 91db efficient, my Midrange is 88db. Should I attenuate the Tweeter and Bass to bring them in line with the Midrange, using a L-Pad circuit in the crossovers?
Old 7th October 2006, 12:46 AM   #4
Speakerholic
Cal Weldon's Avatar
You may wish to put an L-pad on the tweeter but may not need anything on the woofer. It depends on your objective with the speaker. It is easier to attenuate the higher frequencies. Also, a lot of woofers are rated for an SPL at a frequency higher than the XO point so it may not need anything.
Old 7th October 2006, 12:49 AM   #5
Thanks Cal good point, it makes the building of the Xovers easier.
attenuation using I/V ailouros6 Digital Source 14 15th October 2008 06:20 PM
XLR to RCA with attenuation pad. KOL69 Everything Else 1 24th April 2008 11:10 PM
hum attenuation AndrewT Power Supplies 3 2nd July 2006 09:12 PM
10 dB attenuation box june Parts 2 20th July 2004 04:07 AM
Attenuation Nappylady Multi-Way 3 18th February 2003 12:07 PM
Page generated in 0.08313 seconds (73.18% PHP - 26.82% MySQL) with 10 queries
