trying to find a 3" driver that has a very shallow mounting depth. About 3/4" is the max. Any ideas what I could consider ?
This is for replacing the inside speaker of a couple of sortwave/communications receivers so doesn't have to be hi-fi, just something that doesn't sound really bad! or is atleast listenable! |
#2 |
I got 60 3" drivers 45 ohm that would work.
#3 |
45 ohm ? although anything in the 4 to 16 ohm range would be better, this might be worth trying, because I haven't found anything else yet
. What is it you have got ? Could you provide any more details ? Thanks.
#4 |
The Aurasound NSW2 might work for you. If you mount from the flange back, it's 1/2" depth, with the remaining 1/4" available for venting some of the back pressure.
-Zaph|Audio- |
#5 |
I got 60 of them from BillF. No parameters but heres a picture:
http://www.diyaudio.com/forums/attac...amp=1155323525 Now that I look at them, they are 1 inch deep from back of mounting flange. If you want a couple I can spare them no problem, just shipping for ya. |
#6 |
zaph, mounting that 2" driver with the extra voluptous surround foam might be tricky. The flange dimensions might be off too.
relax, before I have you send one or two all the way here would you mind measuring the dimensions of those puppies ? I need the flange and mounting hole distances, mounting depth and also the magnet diameter. |
#7 |
sure thing:
They are exactly 3" x 3". The holes are 2 1/4" apart and 3/8" from the edges. Exactly 1" from flange to magnet backplate, and magnet is 1 5/8" diameter. Also- I am in Dayton, MN. SO its not that far. |
#8 |
Percy, what is it you want to do with those speakers? As far as I know 45-ohm drivers are usually used in commercial or office environments for PA/paging purposes but I imagine using 4 in parallel can lower impedance enough for audio use... I'm just being curious.
#9 |
Hi relax,
just wanted to let you know that I am following a few good leads that might help me find a speaker that is a better fit - both physically and electrically. http://www.kiwa.com/ATS909.html (see note about replacement speaker at the bottom of the page) http://www.radiolabs.com/products/re...s/super909.php (their audio mod includes a different speaker with better fidelity) There is also buzz about the Sony 7600/7601 receiver speaker being of great sound quality so that is also an option. willitwork, like I said in my original post I am looking at replacing the stock speaker on a communications receiver - http://www.universal-radio.com/catal...rxvr/2786.html |
| 12" "guitar" driver in Audio Speakers | jwhit67 | Multi-Way | 4 | 11th February 2008 03:47 PM |
| "open air" mounting a tweeter | Pete_L | Multi-Way | 1 | 13th November 2006 03:36 AM |
| when the datasheet says "vertical mounting: up or down", does it mean... | jarthel | Tubes / Valves | 1 | 2nd November 2006 07:43 AM |
| what is the mounting depth and mounting diameter of this? | lemans23 | Multi-Way | 2 | 26th October 2005 11:52 PM |
| Page generated in 0.09717 seconds (84.07% PHP - 15.93% MySQL) with 10 queries |
