Old 4th October 2006, 05:19 PM   #1
Default Enclosure size for Vifa woofer
Vifa PL26 woofer
Vifa PL26 Datasheet
Need input. Should I go with a vented box. If so - I have used various (freeware) programs and have gotten volumes from 75 L to 96 L.
Thanks.
Old 4th October 2006, 06:06 PM   #2
I'd say it was designed for sealed box loading, 45L to 60L.
/sreten.
Old 4th October 2006, 06:12 PM   #3
ok thx. software shows 48L sealed enclosure which would be slightly easier to build. Do you have a program showing dimensions that should be used. The one I use would build a enclosure that would make look like it is from the 70's (wide and high - not very deep). All the new (retail) designs seem to be just wide enough for the drivers and deep. Is this going to make much difference.
Old 4th October 2006, 06:42 PM   #4
If you haven't done so yet, you may want to have a look at Solen's woofer application suggestions for this driver. The PL26 is towards the bottom of the page. I believe the values on that chart are provided by the driver manufacturers themselves.
http://www.solen.ca/woofapp.htm
Old 4th October 2006, 06:53 PM   #5
vinylkid58's Avatar
Tall slender speakers are less intimidating and easier to incorporate into the living space (WAF). Some of use can't get away with having wide baffle speakers unless there is a dedicated listening room.
The width of the baffle does make a difference:
http://www.t-linespeakers.org/tech/b...tep/index.html
Are you building bass boxes or a 2/3-way system?
Jeff
Old 4th October 2006, 06:59 PM   #6
Woofer will be in its own box.
Old 4th October 2006, 07:05 PM   #7
vinylkid58's Avatar
So is it going to be a sub then, with satellites? Is visual appeal important, or can you hide them?
Jeff
Old 4th October 2006, 07:34 PM   #8
chrisb is online now chrisb  Canada
48 liters is 2929 in^3 ; an exactly cubic box would measure approx 14.325" internally
Given the size of the driver, you could acheive this volume with any combinations of dimensions with a minimum of 10.5" for the driver panel. However, your baffle step frequency at that dimension will be in the neighbourhood of 1130Hz. If intended as a woofer only (i.e from 150 or so down ) this won't be much of a concern - you'll have boundary loading and room gain working for you, but if you're planning on extending into the midrange area, you could have issues. **
I've always had good results with enclosures dimensioned around a "golden ratio" formula, (i.e. divide and multiply the cube root of net volume by 1.618) and for a simple sealed box, one with progression of .618D/1W/1.618H.
** well, it looks like that's been answered, but it does raise another - will this be powered by dedicated plate amp? If so, then definitely allow for sealed compartment in the enclosure.
Allowing for a single layer of 3/4" material, you'd have an approx 15 5/8" cube, less allowance for bracing and amp enclosure.
Having said all that, the Adire Extremis 6.8 might be worth consideration; don't let it's size fool you - this thing can put out prodigious amounts of bass, and requires only 21liters in a ported box tuned to 33Hz. The biggest problem I've had using these is finding a plate amp small enough to fit the box .
Old 5th October 2006, 06:19 PM   #9
Richard Ellis's Avatar
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
Default To port or not to port!
OK...this is what I came up with for a port job.
Volume of box (Vb) 3.90493761 cubic feet
Box resonance volume (Fb) 26.46396468 Hertz
Cutoff frequncy (F3) 26.27292166 Hertz
3" port length 4.771110565 inches
I figure a pair of them in the golden ratio in two seperate boxes....stealthly positioned should work just fine.
Don't expect stellar roaring performance from these as they will be power eaters at only 87 db SPL....on top of that only being 6.5 " drivers they are more suited to a relatively small room.
________________________________Rick.......
Old 6th October 2006, 09:49 PM   #10
OOpps....10"
__________________________________Rick...
Enclosure size for Adire AV 8" woofer? Big_Bill Multi-Way 7 21st May 2009 10:30 PM
SUB woofer enclosure size sumovanner Subwoofers 3 4th December 2008 04:32 PM
How do . .size of Isobaric Woofer enclosure for small car chub2 Multi-Way 1 25th April 2008 03:00 PM
Sealed box size for Vifa M26wr-0908 .? JandG Subwoofers 5 12th November 2006 03:41 PM
Enclosure size for Vifa M26WR 10" The Paulinator Multi-Way 7 21st December 2003 05:46 PM
Page generated in 0.10521 seconds (80.30% PHP - 19.70% MySQL) with 10 queries
