Old 4th October 2006, 07:56 AM   #1
Alex_J is offline Alex_J  Russian Federation
Send a message via ICQ to Alex_J
Default Accuton C92-6+ETON ER4 project
At first sorry for my uglly english )
Recently I designed a series x-over network for this drivers. Calculations in LEAP based on frd files which was made from manufacturer's data, phase information reached by minimal-phase transform in LEAP. Undortunatelly I haven't exact indormation about acoustic phase ofsets of this units. If any have such information and give it to me, it would be very helpfull to compete the design.
Anyway, thanks for cooperation ))
P.S. Phase and frequency responces calculated with VC ofsets = 10mm (C92-6 deeper from acoustic plane by 10 mm and it's center below the tweeter's one by 140 mm). So for optimal box construction I might to know a needed physical displacement for units.
Old 4th October 2006, 08:03 AM   #2
Here is FR in phase and out of phase.
Old 4th October 2006, 08:05 AM   #3
And electrical slopes of x-over
Old 5th October 2006, 02:24 AM   #4
So could ANYBODY Help???
Old 5th October 2006, 11:47 AM   #5
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
You need to know your BSC and you need to know your offsets by measurement on final box. The way you do it is a long shot I am afraid.
P.S.
If such a curve was real it would be bound to sound bright IMHO.
Old 5th October 2006, 03:08 PM   #6
Calvin is offline Calvin  Germany
Calvin's Avatar
just as things happen, I have had driver combination a while ago.
The filter I made was a parallel one with a second order Highpass
(6,8µF-0,8mH/0,2Ohm) and a voltage divider with 4,7Ohms seriall and 15Ohms parallel. The ER4 was connected out of phase. The Thiel C92
had a series inductance 2mH/0,25Ohm and a parallel RLC-notch consisting of 0,4Ohm/0,1mH/10µF
maybe that helps ;-)
jauu
Calvin
Old 6th October 2006, 02:30 AM   #7
1. There is no any brigt sound - Er4 is an AMT driver and never sound brigt may be because of narrow vertical dispersion.
2. Calculations of last schematics had demonstrated appr. by 6 dB recessed midrange across x-over frequency with ANY displacements between VC whithin 0..65mm.
Have you mesured combined response?
And how good did it sounds at all?
PS. Possibly I don't said that used ER4 almost as a dipole (there is a big box behind them) So it's FR is different from one with tight closed back side as ETON recommends.
My ears tell me that as more space behind the diafragm of ER4 the more open and livelike sound it's demostrated.
In what way you had used 'em?
Old 6th October 2006, 05:52 AM   #8
Calvin's Avatar
I rely on my own measurements.
It was a small ´classical´ bookshelf-Design with the ER4 playing onto a very small back chamber.
jauu
Calvin
Old 6th October 2006, 06:16 AM   #9
1.How you can estimate overall perfomance?
2. Is this schematic demonstrated good phase summation around x-over region? I mean a deep null in reversal case...
Old 6th October 2006, 05:21 PM   #10
Calvin's Avatar
actually I can´t remember. A friend needed a crossover for it and I made it.....haven´t heard the little beast intensively. But he never complained either ;-) I just had some data left about it on the computer and thought it might have helped.
jauu
Calvin
accuton and eton prices ermes Multi-Way 2 4th December 2005 07:49 AM
Eton or Accuton or ??? foo Multi-Way 4 14th August 2004 02:02 PM
Help with crossover for Accuton and Eton? guru Multi-Way 1 8th August 2004 10:08 AM
ACCUTON (THIEL) or ETON Kal Multi-Way 16 27th July 2004 07:35 PM
3-way Eton/Accuton TL question Jan Deckers Multi-Way 0 27th May 2004 07:41 AM
Page generated in 0.12919 seconds (77.95% PHP - 22.05% MySQL) with 11 queries
