Old 4th October 2006, 05:06 AM   #1
jleaman is offline jleaman  Canada
Send a message via AIM to jleaman Send a message via MSN to jleaman Send a message via Skype™ to jleaman
Default Speaker Accomplishment Thanks chris & dave
Here they are people. Yes they are glued together. These are just test boxes to see how the driver sounds and reacts to being ported. So far i like it. For me tons of bass. They are ported out the bottom at the back.
Old 4th October 2006, 05:08 AM   #2
Bottom
Old 4th October 2006, 05:36 AM   #3
ruerose is offline ruerose  Canada
are they a kit from planet10?
Specs please
Nice looking so far
Old 4th October 2006, 05:44 AM   #4
NO they are not a kit from him. These drivers are far from what he would buy. They are my choice of driver and tweeter. He helped me design the box as i wanted a book shelf / low profile speaker box and it to be ported. So he designed the box i asked Chrisb to cut the wood to which he did then i glued them together.
I did make one mistake. I didn't notice till i was done. To late now, you can see that the front baffles are glued on the same it was suppose to be flipped so the tweeters are reversed. They are beta boxes so we will see what the real final version looks like.
So far they are running off a class ab amp for break in time and sound not to bad so far.
Jase
Old 4th October 2006, 06:53 AM   #5
Geek's Avatar
Looking great, Jase!
Old 4th October 2006, 06:56 AM   #6
Thank's Geek
Old 4th October 2006, 02:38 PM   #7
NOw to connect a set of aleph's and listen to better sound.
Old 4th October 2006, 04:11 PM   #8
badman is online now badman  United States
Custom Title
badman's Avatar
Default can't tell....
Are the drivers flush mounted? If not, it would be a very good idea to do the tweeter, failing that, a thick felt ring surrounding the tweeter flange would help reduce the edge diffraction.... edge diffraction on normal 104mm tweeter flanges is a real nasty customer.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 5th October 2006, 05:56 AM   #9
Default Re: can't tell....
Drivers are not flush mounted the purpose of this box right now is to test sound and to see how it act's in this enclosure.
When the final design is done i'll have the tweeter closer to the midd bass and left and right speakers will not be the same
I think on the final design also ill be rounding over the edges.
Jase
Old 9th October 2006, 05:49 AM   #10
I got the time to get over to daves house and use fuzz box. Can any one shed some light on this and help me design some speaker xover's I think dave said id have to go with a 3rd order. 6 part's count.
Please.
Jase
Chris Babineau Chris Babineau Forum Problems 2 9th February 2009 06:53 PM
Introducing Mr Chris Mr Chris Introductions 4 5th February 2007 04:07 PM
Altec 409-8D speaker info? Dave? Anyone? Nanook Multi-Way 11 17th January 2007 06:14 PM
Hi I'm Chris and this is my new Pass Pen. Zen!! bart_dood Pass Labs 16 7th December 2003 11:11 PM
Page generated in 0.11438 seconds (78.76% PHP - 21.24% MySQL) with 11 queries
