Am I right or wrong about this ... sandcast resistors labeled
15W6R8J - means 15W, 6.8 ohm 3W4R3J - means 3W, 4.3 ohm |
#2 |
yep.
#3 | ||
I think you are right |
#4 |
Does anyone kow what the J is for?
It's probably not important but I'm curious to know.
Martin + + |
#5 |
Did it Himself
J = 5% tolerance, K = 10% tolerance
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
Thanks to those that replied ... here's another question about reading a capacitor. It's marked 825K 250V. The 250V is obvious, but does the 825K mean:
8200000pf or 8.2uf, 10% tolerance Hmmmm |
#7 |
Did it Himself
8200000pF, 10%
#8 |
Would a 6.8K100 Cap be simply 6.8pF 100Volts?
Sorry for being a bit dumb but I'm a little confused by the decimal point and want to get the correct value. Thanks in advance for your help.
Martin + + |
#9 |
Did it Himself
I would think so. There is a slim possibility it could be 6.8nF, but pF is far more likely.
| Quickie question about Amp3 - this is really stupidly simple. | Spasticteapot | Class D | 1 | 24th November 2006 10:38 PM |
| 0A3 and pentode questions (quickie) | Simpleton | Tubes / Valves | 8 | 16th July 2005 06:34 PM |
| Turntable quickie. | Bose(o) | Analogue Source | 11 | 26th August 2004 08:46 PM |
| screen-plate resistor and grid leak resistor | metebalci | Tubes / Valves | 4 | 26th February 2004 03:18 AM |
| Re-tubing Quickie M60 (EL34 quads) | wheezer | Tubes / Valves | 10 | 4th March 2003 01:52 AM |
| Page generated in 0.09294 seconds (80.41% PHP - 19.59% MySQL) with 10 queries |
