Linkwitz Transform Circuit for Dipole Bass
Greetings -
I wrote Siegfried himself about this a few day ago - I was just curious if the circuit could be applied to a dipole bass setup. This was his answer:
"The LT could be used to lower the low frequency roll-off of a driver before applying the 6 dB/oct dipole correction to it."
So now I'm wondering if any of you have considered this, or have actually built a system this way or are planning to?
Thanks!
Account Closed
Joined 2001
richie00boy said:
It could be used, but the reason I suspect it hasn't is because it would quickly lead a system into silly power territory.
Well, not really. The Xmax of the driver largely determines the SPL capability at low frequencies for a dipole config. And that is the frequency area you would most likely be correcting with a bi-quad setup like the LT. With or without correction, power requirements would still be considerably less than the same driver in a nominally-sized sealed box.
Equalization doesn't increase the ultimate SPL capability of the driver/amplifier combination, but it does make it use-able over a wider frequency range.
sdclc,
You can certainly use the LT topology to place two new poles even if the driver is not in a box. (The box is just really big.) Then, once you mount it in your dipole baffle of choice you should have just the 6db/octave cancellation and possible cavity resonance to address. Siegfried uses this same technique (with a somewhat simpler topology) on many of his designs.
http://www.linkwitzlab.com/filters.htm#9
Davey.
More specifically SL seems to like shelving low-pass filters which each provide a single zero and pole.
If you look at SL's publically available Orion documentation you'll find a 20-110Hz shelving low-pass for driver eq, 20-305Hz for dipole eq, and final speaker high-pass response which retains the drivers' pole at 5Hz so the excursion increase doesn't continue to DC -
http://www.linkwitzlab.com/orion_asp.htm
http://www.linkwitzlab.com/orion_challenge.htm
Account Closed
Joined 2001
Drew,
Yes indeed, I'm well familiar. :) In the case of the Orion the driver-specific EQ required is almost completely accomplished via the simple shelving filter topology.
There is also another example of "cascaded" shelving filters to accomplish a specific goal in the EQ setup for the Thor, sealed-box subwoofer.
http://www.linkwitzlab.com/thor-eq.htm
The original reference from many years ago:
http://www.linkwitzlab.com/images/graphics/f0Q0fpQp.gif
The "realizability criterion" in the math result being the go/no-go decision as to whether the LT topology can be used.
Davey.
