I've been digging for a couple days, trying to find a software suite that can do the following.
- Measure a raw driver and give the necessary for modeling T/S parameters - Measure speakers response and impedance curves both for infinite baffle and in and enclosure. - Take parameters and measurements to give suggested crossover networks - Can generate necessary signal output for said testing - And a few other things like measure THD, generate spectral decay plots There's probably other stuff I'd want or need that I haven't thought of. The two pieces of software I've found are http://www.fesb.hr/~mateljan/arta/index.htm http://purebits.com/scoverview.html Are there others I should look at as well? What is the recommendation here for something easy to use, and powerful enough to get the job done? |
#2 |
#3 |
That does look nice, but I'm on a PC ...
#4 |
How about the Soundeasy/Boxcad sold at parts express for $189? http://www.interdomain.net.au/~bodzio/
#5 |
I use SoundEasy and so does many others. I am very happy, it will do all you asked and then some.
#6 | |
| Speaker Testing Software - which one's actually good? | hifimaker | Multi-Way | 76 | 21st April 2012 04:54 AM |
| thiel small testing software? | mhtplsh | Multi-Way | 3 | 26th December 2007 05:02 PM |
| New Software For Testing | jwatts | Multi-Way | 2 | 5th November 2004 09:26 PM |
| DAC Testing Software | Ulas | Digital Source | 8 | 30th April 2004 01:11 AM |
| Software Analysis Testing | RobPhill33 | Everything Else | 9 | 24th February 2003 09:37 AM |
| Page generated in 0.09186 seconds (78.17% PHP - 21.83% MySQL) with 10 queries |
