I'm trying to learn this stuff, slowly but surely
#2 |
Maybe the speaker plays down to 60hz. From what I see for components I do not see anything that indicates a 60hz crossover point.
~1600hz if a 6 ohm low pass with what looks like a zobel is the lowest part. the center is a 12db/oct low pass and the top is a 18db/oct high pass with attenuation for the tweeter. If you have the nominal impedence of the drivers it would be easier to understand the crossover. |
#3 |
All the drivers are rated at 6 ohm.
#4 |
You probably could have guessed, but from top to bottom is the tweeter, midrange, then woofer. And like I was saying, the paperwork says the crossover points are 60hz for the woofer, bandpass 3200 for the mid, and 3200 highpass for the tweet.
#5 |
60Hz must be a typo. From the values in the crossover, 600Hz seems far closer to the mark.
#6 |
Unless the woofer is somehow installed in a bandpass (mechanical) configuration through cabinet design there is no way those values could yield a 60Hz cut-off. Large ferrite-cored inductors could mean there's a mistake on the schematics printout.
#7 |
Its a 2.5 way crossover. There is no 60Hz c/o. |
#8 |
I think 0.6mH on low woofer might be typo error....6mH would make a lot more sense
#9 |
LOL, just had a glance at the Wharfedale Evo. Should've done that first then I wouldn't have bothered with wild theories. Like Sreten posted it's a 2.5 way speaker, not a 3-way, and the LF cutoff is listed as 160Hz even though the literature is void of details on how this is achieved. Woofers are only 6-inchers (17cm) so my guess is that cabinet cavity bandpass filtering is used.
This being said the xover schematics still looks a bit odd, and it's out of phase. |
#10 |
Sorry if I implied it's a 3way, you're right it's a 2.5 ...
| Can some one explain me this amp? | Tarzan | Solid State | 22 | 3rd January 2008 07:06 AM |
| Please explain this crossover...??? | gcm908 | Multi-Way | 44 | 1st November 2006 06:03 PM |
| Explain this crossover | audiokid25 | Multi-Way | 9 | 8th July 2005 09:58 PM |
| please explain this crossover... | gcm908 | Multi-Way | 7 | 17th February 2005 07:17 AM |
| Page generated in 0.10605 seconds (76.79% PHP - 23.21% MySQL) with 11 queries |
