Old 29th September 2006, 11:51 PM   #1
masta is offline masta  Canada
Default searching for a 600w amp project
I have a 600va transformator and two big 37 000Mfd capacitors. I would like to make a stereo 300 watts amp.. any suggestions?
thanx
Old 30th September 2006, 02:45 AM   #2
nate is offline nate  United States
I would check out the Pass Labs forum though you may not find too many designs that are in the 300 watt range. You definetly will find something that has the potential to sound great as well as some great resources in the regular contributors.
http://www.diyaudio.com/forums/forum....php?forumid=8
The secondary voltage rating would be an important piece of info-
Good luck
Nate
Searching for a minimum 400W@8 ohms amp project Leolabs Solid State 16 26th July 2009 01:37 PM
FS: Carver M1.5T 600w rms 8 ohm/channel Bent Swap Meet 0 3rd June 2008 03:49 PM
new project - searching... yuval Pass Labs 4 13th July 2003 09:40 PM
Searching for a good TL project wake rider Multi-Way 7 8th January 2002 06:57 AM
Page generated in 0.07310 seconds (59.72% PHP - 40.28% MySQL) with 10 queries
