Old 29th September 2006, 08:26 PM   #1
gcm908 is offline gcm908  United States
Default Please explain this crossover...???
Can someone please walk me through this crossover? Thanks GCM
Old 29th September 2006, 08:31 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
woof have 12db/oct
tweet have 24db/oct with few resistors for level padding and 0,5 UF for augmenting highest frequencies driver can play
ya need more ?
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 29th September 2006, 08:36 PM   #3
Thanks Zen Mod...
How would the 0,5 uf augment the hf? raise or lower? and
if the hf is 24db, why would it be wired in reverse? -/+
Any way of knowing the xo frequency without building it?
Thanks again.
Old 29th September 2006, 08:53 PM   #4
Zen Mod's Avatar
Originally posted by gcm908
Thanks Zen Mod...
Thanks again.
0,5UF is for raising from some frequencies ...probably driver (as all drivers) have somewhat falling characteristic
12db/oct twist polarity 180 grades
24db/oct twist polarity 360 grades.......so reversing polarity equals twisting of polarity in low and high legs
but-without knowing exact placement of drivers (horizontal offset-how drivers are mounted in vertical plane) it's hard to have any further comment on phase characteristic of sayed combination........
I can give you xo frequency tomorrow,just because exactly this formula is always slipping form mu mind ,and I always must check in Loudsp Cookbook......
Old 29th September 2006, 08:57 PM   #5
v-bro is offline v-bro  Netherlands
v-bro's Avatar
This filter is specifically tweaked for a certain driver combination. For knowing xo you'd at least need to know the impedance of the drivers.
The switched polarity is done in order to restore the phase. Phase behavior difference between the drivers and different filter slopes can sometimes make it necessary to change the polarity of a driver in order to improve the phase behavior of the combination.
The 5uF cap functions as a 6db/oct. filter(at a higher xo-freq.) parallel to the 24db/oct. filter in order to improve highest frequencies.
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 29th September 2006, 09:00 PM   #6
v-bro's Avatar
Whoops, I ment the 0.5uF cap....
Old 29th September 2006, 09:11 PM   #7
Zen Mod's Avatar
incorrect
resonant frequency of circuit is dependant solely of L and C parts ;
but-their values depends of drivers impedance,so -L is doubled and C is halved for 8 ohms,comparing to 4 ohms dedicated xover
Old 29th September 2006, 09:15 PM   #8
hermanv is offline hermanv  United States
I did a quick simulation.
The simulator is free at the Linear Technology site.
Old 29th September 2006, 10:42 PM   #9
v-bro's Avatar
Originally posted by Zen Mod
incorrect
Whoops again, you're right...("I knew that....." )
Great input on that linear technology site Hermanv!
Old 29th September 2006, 11:07 PM   #10
You can build driver models (at least the RLC parts) and then save them as if they were a component. The simulator has no driver library and doesn't know anything about acoustic driver behavior or mechanical Q.
For the chart I posted I just put in 6 Ohms DC for both drivers. I didn't sum the two outputs, but you can by adding an algebraic equation to the plot window.
There's a LTC users group on Yahoo that has sim files for some common vacuum tubes and other useful stuff.....
The FFT functions are also very useful for simulating amps, be sure to use a large number of samples and very small step sizes for performance better than 40 or 50 dB. (just right click in the plot window)
Can some one explain me this amp? Tarzan Solid State 22 3rd January 2008 07:06 AM
Another please explain this crossover ... TurboFC3S Multi-Way 18 3rd October 2006 03:08 AM
Explain this crossover audiokid25 Multi-Way 9 8th July 2005 09:58 PM
please explain this crossover... gcm908 Multi-Way 7 17th February 2005 07:17 AM
Page generated in 0.10879 seconds (78.55% PHP - 21.45% MySQL) with 11 queries
