Old 23rd September 2006, 11:21 PM   #1
sqlkev is offline sqlkev  United States
Default Adjustable speaker spikes
Anything cheap and effective?
I'm not much into the ones that partsexpress carry, prefer a different look.
Old 23rd September 2006, 11:26 PM   #2
http://www.madisound.com/
They've got a pretty good selection and not too expensive either.
Old 23rd September 2006, 11:39 PM   #3
I'm actually browsing through madisound right now.
Wonder how much adjustments I need, I'm sure my floors aren't flat and leveled.
Old 24th September 2006, 12:39 AM   #4
sdclc126's Avatar
If you go "tripod" - use three in a triangular array - they are pretty much self-leveling.
Supercell audio has several different types of spikes, and Mach 5 Audio has some cool little ones - cheapest I've seen.
Soft Dome
Old 24th September 2006, 01:36 AM   #5
The triangular idea sounds good! Thanks for reminding me of that.
BTW, does it make sense to add spikes to the bottom of the bookshelves (between the cabinet's and stand) and another set under the stands??
Old 24th September 2006, 02:38 AM   #6
sdclc126's Avatar
Well it can't hurt - probably not something you can overdo! You can think of the stand as an extension of the speaker, but that means the speaker should be rigidly coupled to the stand so they act as a unit. This could be done with spikes or even by bolting the speaker & stand together.
Soft Dome
Purpose of speaker spikes? cyberspyder Multi-Way 108 13th September 2008 01:29 PM
Solid brass speaker spikes peterphan Swap Meet 1 6th July 2007 01:38 AM
FS: Black Chrome speaker spikes akunec Swap Meet 1 19th May 2007 11:32 PM
Double sided speaker screws/spikes eRiCdWoNg Multi-Way 4 2nd February 2004 02:44 AM
Large speaker spikes eRiCdWoNg Multi-Way 5 12th December 2003 01:10 AM
Page generated in 0.06923 seconds (80.89% PHP - 19.11% MySQL) with 10 queries
