Surrounds, its love 'em or hate 'em in.
Most commercial dipoles and bipoles I see are often not implemented correctly(or at least not how I'd like it done) and I was wondering if there's a concencus on how they should ideally be designed? Considering a bipole as an example, which would be used in a small room and be expected to offer increased spatial information for music and movies, what would you consider out of the following as optimum or worthy of consideration for further improvement: Dual fullrangers firing at 45 degrees to each other Single forward firing tweeter crossed at ~2Khz to dual 4" mid/bass firing at 45degrees to each other. And an 8-10" downfiring woofer crossed at 80hz or below. Dual tweeters and mid/bass firing at 45 degrees to each other and crossed low ie, 1-1.5Khz. And an 8-10" downfiring woofer crossed at 80hz or below. Perhaps this isn't the way to go at all and maybe an omni design with something like a deflector for the stuff from 200hz up. Again I see little theory or implemented and successful DIY designs. One that did catch my eye was Visaton's omni floorstanders which are available as a DIY kit but that would seem to be taking much of the fun away. Or expanding on the Omni designing, using something which takes advantage of room surfaces such as ceiling and walls to bounce sound. Sounds nasty but I know of at least one design that does this. Or maybe just a wide dispertion monopole design such as a 3/4" dome with 3" dome mid and suitable bass driver. There's not really much talk so hopefully you can help me make my mind up and cement some kind of ideal for an in-ideal speaker. |
#2 |
I always liked the idea of, in back surrounds, A 4 or 5" full range firing forward and tweets fireing up. then set the crossover at were the full range would roll off or at around 8-12k Hz... thats me though...
Other than that I got a pair of optimus' that I did a x-over mod on that are aimed around 30deg on the wall from the ceiling that I'm happy with.
----------------------------------------------------- “We are no longer the knights who say ni! We are now the knights who say ekki-ekki-ekki-pitang-zoom-boing!” |
#3 |
I played around quite a lot with positioning surrounds in my old house, and with the little speakers I was using, I found the best results was placing them in the back corners, firing up at the ceiling, mounted about about 50cm down. This was in quite a small room, 5x5m, so it may not work quite so well in a larger one.
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#4 |
I'm looking at using them in a shoebox room anyway Al. I take it those were monopoles?
I've never really heard any decent bipoles or dipoles that take the form of surround, I'm not talking about Linkwitz's Orion or the like |
#5 |
Hi Sid216
That funny, your idea with tweeter pointing upwards Exactly what I have thought with my CSS125FR/XT19 At 10khz it might deal with not interfering so much with a widerange...I am not started yet, so I only guess, but tweeter might not need much attenuation |
#6 |
Check out this comparison of each type, Shin.
http://www.hometheatermag.com/loudspeakers/25/ In the end, I decided a regular monopole was the safest, and most versatile option. It's nice to have the option to use it as a main speaker when the need arises. |
#7 | |
I always thought a good quality full range with a reflecting tweeter would be ideal. with the tweeter bouncing around from the ceiling and walls, it would create a kind of delay making the room sound as if there is a little more depth. and with the wide range, the x-over would be dirt simple, just a 6db at least. edit: as a test, build a simple enclosure and just set the tweeter on top to see how it sounds. I test small woofers in shoe boxes to see how they react. its simple and a bit effective.
#8 | ||
That said, a friend of mine had a 5.1 set of defintive technology speakers and after hearing those I don't think i'd be able to go back to having surrounds that weren't truly full range. I forget the name, they were bipolar and had built in powered subs. It's amazing how much information is in those surround channels on certain dvd's, and I don't think they can be done justice with a surround that might hit 80-150hz at best and a single subwoofer for all five channels. You don't realize how much you've been missing until you hear a fullrange 5.1 setup IMO. They were small enough to put on a wall aswell. Quote:
Tristan
When I was young I really wanted a bicycle, I used to pray every night for god to bring me one. But as I got older I realized god didn't work that way so I stole one and begged for forgiveness. |
#9 |
Movie theatres generally have 3-4 speakers on each side for wide, even coverage of the surround channels, then 2-4 (depending on the size of the theatre) for the rear surround channel. For larger rooms why not consider doing something similar with a bunch of small (say 1in+5in) monopoles, you can run them in series and parallel to keep ye' olde amp happy.
#10 |
many manufacterers use angled bipoles to create a sense of space in a small room;
http://www.energy-speakers.com/v2/pr...age.php?id=298 and; http://axiomaudio.com/surroundspeakers.html is this just a marketing ploy? the only DIY info on the subject that i have found is; http://www.gr-research.com/index.asp...ROD&ProdID=113 any new ideas? blue934 |
| RE: Rotting Surrounds | li_gangyi | Multi-Way | 6 | 22nd May 2005 05:54 AM |
| need a 5-6" mid for surrounds | minitruck_freq | Multi-Way | 1 | 5th April 2005 01:03 AM |
| diy surrounds | aarono | Multi-Way | 4 | 24th March 2005 06:40 AM |
| Dipole (-ish?) surrounds | tiroth | Multi-Way | 11 | 8th December 2004 07:09 AM |
| Monopole surrounds | dc | Multi-Way | 2 | 29th December 2001 03:39 AM |
| Page generated in 0.13035 seconds (84.50% PHP - 15.50% MySQL) with 11 queries |
