neodymium speakers ?
Old 23rd September 2006, 05:27 PM   #11
angsuman is offline angsuman  United States
Disregarding expense, I'd love to see say a woofer's magnet replaced by a same size neodymium it'd probably be hundreds of dollars, and would probably kill something if its not sheilded. I'd expect a definite increase in performance.
Old 23rd September 2006, 05:28 PM   #12
poobah is offline poobah  United States
poobah's Avatar
I got the mumble part...
What about the flux modulation?
Old 23rd September 2006, 06:08 PM   #13
R.I.P.
I'd love to know which T/S parameters depend on flux density. Then see what effect that would have on the performance.
regards Andrew T.
Old 23rd September 2006, 06:10 PM   #14
poobah's Avatar
I would speculate that the weight of a conventional ceramic magnet coupled with the larger diameter of the voice coil would both be good things for woofer.
Old 23rd September 2006, 06:36 PM   #15
Rademakers is offline Rademakers  Netherlands
In PA applications neodymium is used to make drivers, that for a given performance will have about half the weight of the ferrite versions. For a double 18" the difference will be around 12 kg (25 lbs) which can make the difference between one man or two man lifts.
Also since the introduction of neodymium the decrease of Qts is encouraged (often in midbass units).
Wkr Johan
Impossibilities we do immediatly, miracles take slightly longer.
Old 23rd September 2006, 07:55 PM   #16
v-bro is offline v-bro  Netherlands
v-bro's Avatar
A decrease of Qts indeed, as can simply be seen on pic's in brochure's. Drivers tend to have lower Qts when haveing a larger magnet.
An other advantage -seen from an "audiophile" point of view- I would recon is less air-flow noises and reflections within the driver.
Where less reflections will probably only be an advantage in mid to highrange applications and less air-flow noises in bass applications (dipoles and ripoles!).
I have two neodyme magnets from a Bowers and Wilkins "Nautilus" , the magnet poles in them are very uniquely shaped (drilled through) obviously to decrease reflections. (sort of reversed horn-shape).
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Old 25th September 2006, 02:33 AM   #17
rmsaudio is offline rmsaudio  United Kingdom
Thanks for all the feedback, much appreciated!
I was going to remove the post as a forum search shows the topic has been
well discussed.....guess I should have searched first, so often the case with this forum (well supported, quality posts covering most topics)
Like all things audio, it comes down to application
Thanks again!
Old 27th September 2006, 01:21 AM   #18
Ken L is offline Ken L  United States
I believe the different size of the NBd magnets allows the manufacturer more versatility in the design.
In that, certain physical variations are available to him that would not be with ferrite.
Seems like I have seen mention of that on one of the Lowther drivers - so I'm not sure that would follow thru with non-full range designs.
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 27th September 2006, 01:53 AM   #19
thoriated is offline thoriated  United States
Neodymium has the greatest flux decrease with increasing temperature of any magnet material commonly used in speakers, as opposed to, say, alnico, which has the least. This is reflected in the two materials' relative curie temperatures.
Old 27th September 2006, 01:37 PM   #20
blumenco is offline blumenco  United States
Default neo, alnico
yeah, and alnico just sounds good...
unlike ferrite chunks.
neodynium I believe is inherently sheilded, (closed magnetic circuit) like alnico as well, I beleive.
for paper cone stuff, alnico just works. good tone. appplication, as said above...
neodyniumm could be tuned too strong perhaps. creating more bends in the process(?)
I do tend to like the sound of neodynium stuff though. in general.
eh who knows.
Clark
neodymium speakers ?Hide this!Advertise here!
If neodymium is all that great . . . Bill Fitzpatrick Multi-Way 153 8th October 2008 09:05 AM
Neodymium magnets NickC Full Range 1 19th May 2008 09:41 PM
Neodymium magnets Geoff H Planars & Exotics 0 18th June 2007 12:59 PM
Neodymium Magnets Frazzled Everything Else 4 25th July 2004 05:42 PM
Neodymium Magnets sdman Multi-Way 7 7th January 2002 06:34 PM
