Old 22nd September 2006, 05:21 PM   #1
Question L-R active crossover ?
Hi all,
I have just powered up a 4pole Linkwitz Reilly @ 155Hz running my AE1s and Tannoy Leopards either side of the crossover.
There was lots of thump thump and good vocals, but no upper bass.
Whoopsie, the bass must be out of phase!
I swapped the Leopards phase over (rewiring a Speakon is easy) and suddenly a much better fill in. It needs a lot more work to get it sounding right but at least I've started down that long road.
Q.
What is the phasing of a 4pole L-R crossover?
Is a 2pole L-R the same?
regards Andrew T.
Old 22nd September 2006, 05:55 PM   #2
reins is offline reins  Germany
Hi Andrew,
phase shift of a 4th order L-R is 360° -> speaker are connected in phase.
with 2nd order LR it is 180°.
Stephan
active crossover: fir vs iir netchris Everything Else 3 29th July 2008 09:14 AM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
PA vs DIY active crossover paulspencer Multi-Way 46 27th November 2004 01:25 AM
active crossover aaronboumans Analogue Source 4 31st May 2003 04:59 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.07104 seconds (66.43% PHP - 33.57% MySQL) with 10 queries
