Good speaker's datasheets, along with frequency response, supply
distortions (mostly second and third harmonics) curves. Does anybody know how does "zero level" for these curves is defined? I see two opportunities: - "zero db" level is sensitivity at the same frequency, - it is some kind of "normalized" level, which doesn't depend on frequency (for example, from main speaker's parameters table). Are there any official recomendations? Is there de-facto standard? |
#2 | |
Harmonic 20dB below the fundamental, harmonic shifted 20dB, total difference is 40dB or 1% distortion at that frequency. |
#3 | |
Probably I'll prefer "more frankly" way |
| Cancelling Harmonics | dsavitsk | Tubes / Valves | 20 | 10th July 2007 01:11 PM |
| odd harmonics? | Pbassred | Solid State | 11 | 5th April 2007 12:17 PM |
| Power amp harmonics ? | dakotadave | Tubes / Valves | 21 | 15th May 2006 03:39 AM |
| Artificial Harmonics | guitargully | Instruments and Amps | 1 | 15th April 2004 06:53 AM |
| Phono harmonics | scott wurcer | Analogue Source | 1 | 8th March 2004 09:09 AM |
| Page generated in 0.06942 seconds (75.15% PHP - 24.85% MySQL) with 10 queries |
