Old 19th September 2006, 02:30 AM   #1
Question series Xover
Hello Fellow Scientistsses
Has any of you worked the Trap filters as applied to the tweeter section per Jon Risch's web page on LBI? I find the FIG. H on page 6 to be quite interesting as it solve for a slight droop of 3.5 dB at 18.5kHz to past 20kHz on a tweeter I have been using. Though I didn't tweek this to perfection I witnessed great potential. It actually does what Jon expresses here. It in effect, traps the usable flat frequency and lowers the traped frequency by way of R2 and by inserting C4 your are able to bypass the traped area an allow the last octave or so to come through above the rest giving an airy Hi- frequency lift of sorts. This I can see will help in leveling the output of the tweeter in relation to the woofer.
See www.geocites.com/jonrisch/LBIseries2.htm?200614
In addition to this quest I would like to know has any of you tried this with the AR crossover. It would seem that if things are stable as they claim then this filter may help to place a bit of gain at the droop by way of subtraction.
Francis
Old 19th September 2006, 06:38 AM   #2
Andy G is offline Andy G  Australia
Andy G's Avatar
Hi Francis,
Glad to see you are persevering. I just don't have time to do the measuring stuff or sims etc
Have looked at the LBI and seen it used here and there, but can't remember where, sorry !!!
I just play with them and hope
You should try a 4-way series... great fun !!!!
OS-CON in series for Xover? thespeakerguy Multi-Way 0 7th September 2008 06:13 AM
2nd order LR series xover formulae PeteMcK Multi-Way 30 9th June 2007 07:27 AM
!st order series xover between 5"FR and woofer?? johnmark Full Range 1 2nd May 2005 12:40 AM
Parallel and series components in xover andy2 Multi-Way 7 22nd November 2004 04:32 PM
Series xover design ronjg Multi-Way 26 4th September 2002 07:25 AM
Page generated in 0.08342 seconds (64.35% PHP - 35.65% MySQL) with 10 queries
