Old 16th September 2006, 05:39 AM   #1
Default Question about crossover before amplifier
Im putting together some speakers each speaker will have a tweeter, midrange and 2x woofers.
I have 3 seperate crossovers for HF/MF/LF
Specifically for the woofers I want to have it running from the processor to the crossover then to the power amp, this allows me to split the output of the power amp to each of the woofers.
Old 16th September 2006, 05:59 AM   #2
sdclc126's Avatar
You are putting together an active set-up. What specifically is your question?
Soft Dome
Old 16th September 2006, 06:00 AM   #3
So active is power after a crossover and passive is before?
Old 16th September 2006, 06:05 AM   #4
sdclc126's Avatar
Yup.
Soft Dome
Old 16th September 2006, 06:11 PM   #5
Pbassred's Avatar
Send a message via MSN to Pbassred
you realise that that means 3 power amps? Just checking.
Jeeees! I only asked
www.davethebass.com
Crossover Question ajh Full Range 10 21st September 2007 06:06 PM
Passive crossover before amplifier - biamping thevoice Multi-Way 1 7th July 2007 06:04 PM
Crossover appears to be off on PE amplifier owdi Subwoofers 3 27th November 2006 02:32 PM
Crossover Question woody Multi-Way 3 26th January 2006 11:53 AM
Crossover Question cantskienuf Multi-Way 4 13th October 2004 09:59 PM
Page generated in 0.07589 seconds (73.10% PHP - 26.90% MySQL) with 10 queries
