Old 15th September 2006, 10:52 PM   #1
elvis85 is offline elvis85  Norway
Default plexiglas esl project
Hi I haw bean thinking of building an esl for some time now and figured out that i want to build on in plexiglas.
But what wories me is what I can use to get an conducting surface on the plexiglas while the plexiglas remains somewhat transparent. or if it is at all posibel.
I read an article about using graphite on the diaphrame but is that posible to use on the other conducting surface to?
thank you for reading.
Old 16th September 2006, 02:23 AM   #2
Maybe if you posted on the ESL planar forum you might get more replies
Old 16th September 2006, 03:17 AM   #3
SY's Avatar
You need high conductivity on the stator. Using graphite, you'll need a thick layer and that will not be transparent.
The best transparent conductor is ITO (indium-tin-oxide). It's not hard to put that on plastic with the right equipment, but CVD is beyond the reach of an amateur. You might look at getting ITO-coated polyester film, then laminate that to Plexiglas.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 16th September 2006, 08:33 PM   #4
thanks i will definetly go for the ito. Ekspensiv stuf so i wil mak a smaler one for testing first. and yes sory saw that i shold haw posted in the other section
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
Tapping acrylic (plexiglas, methyl methacrylate) jackinnj Everything Else 12 22nd September 2006 09:43 PM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Page generated in 0.07546 seconds (66.51% PHP - 33.49% MySQL) with 10 queries
