Old 15th September 2006, 03:58 PM   #1
Default Loudspeakers for party
I am a newbie and need help with audio for a party.
- there would be 200 people in hall
- there won't be loud music, but everybody should be able to hear well ( there will be over 50 kids !!)
questions :
- will a 400w amplifier be enough ?
- how many speaker / woofers would be required ?
- should the speakers be placed on floor or on a chair/table ?
- where should they be placed ? diagonally across the hall ? next to each other ?
Old 15th September 2006, 04:10 PM   #2
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
2x600@4 Ohm
4x15 inch +1 inch throat driver cabs. Over long dimension put 2. On the opposite side put another 2 facing the empty distances between the former 2.
Use tripods, height of horn about 2.2 m from floor, little downangle towards midhall if possible.
Old 15th September 2006, 07:26 PM   #3
e-side is offline e-side  Netherlands
Default Re: Loudspeakers for party
Originally posted by lucknowm
-there would be 200 people in hall
Could you give dimensions of the room?
questions :
the power required from the amp to get enough SPL (sound pressure level) also depends on the sensitivity of the speakers. For example, cheap speakers usually need a bigger amp to compensate for the lower sensitivity.
The number of speakers required depends on the capabilities of the speakers (sensitivity, power handling etc), size of the room, available budget etc.
The high frequency units should at least be placed above earheight, higher is prefereable, because when there're many people in front of the HF driver these frequencies won't be heard further away from the speakers, in my experience.
When placing multiple speakers in the same room be sure they work together well. Cancellation of certain frequencies at some places in the room can happen, as well as delayed sound. Usually 'ideal'/good placement is found just by experimenting, there're too many factors that have to be considered, so it's hard if not impossible to simulate. Just trial and error.
Many things just depend on the situation, you can only find out by experimenting. That's what I've learned at least...
regards
Erwin
Old 16th September 2006, 06:16 PM   #4
Pbassred's Avatar
Send a message via MSN to Pbassred
speakers should go against the wall.
Is this a one-off? are you hireing equipment?
Jeeees! I only asked
www.davethebass.com
DIY party in Montreal FrankDIY Everything Else 3 25th February 2006 09:14 PM
DJ / Party Speakers neptunekiev Multi-Way 1 30th November 2004 08:23 AM
It's a 1kPost Party! roddyama Everything Else 13 9th July 2003 10:35 PM
Party time porfi4ever The Lounge 5 1st July 2003 10:26 PM
Page generated in 0.08220 seconds (76.09% PHP - 23.91% MySQL) with 10 queries
