Theroretically, (meaning; I don't intend to do it)
Just say, you had a 12" speaker with a useable frequency of 80 - 3000Hz rated to 80W. And just say, you drove it at 80W but only with frequencies between 1000-3000hz. Would its life expectancy be any different to an identical speaker driven with 80-3000hz? |
#2 |
Hi Pbassred,
Good question. The voicecoil may actually run hotter as it's not pumping as much air. I imagine the driver may run into mechanical failures more quickly. -Chris |
#3 |
and the same question at say 80-200Hz
#4 |
Well, I suppose power is power, 80w at any frequency will heat up the voice coil, but I guess the larger movements at lower frequencies will help to cool it somewhat..
#5 |
Given the impedance curve typical of a 12" driver, the first case would run higher voltage and lower currents than the second. It's unlilkely in a properly designed and sized-for-the-application driver that the difference will be outside normal operating parameters. bigwill might be on the better track that any differnece will be related to excursion rather than power dissipation.
#6 |
Hi rdf,
I agree. Life issues are normally related to mechanical aspects than electrical ones. Mechanical failure of the leads would be a normal failure mode. I think at your lower frequency range, the woofer will lead a normal life. At the higher frequency range given I might expect all kinds of material and glue failures. -Chris |
| Theoretical OPT question | weinstro | Tubes / Valves | 4 | 10th November 2008 08:54 PM |
| Theoretical sub/sat integation question | morbo | Subwoofers | 0 | 28th September 2005 10:37 PM |
| Horns theoretical question | johninCR | Multi-Way | 9 | 16th November 2004 11:08 AM |
| Theoretical SPL vs distance | Cal Weldon | Multi-Way | 12 | 5th May 2004 01:59 PM |
| theoretical question.... | weissi | Digital Source | 15 | 23rd May 2003 05:00 PM |
| Page generated in 0.09251 seconds (74.52% PHP - 25.48% MySQL) with 10 queries |
