Old 13th September 2006, 05:27 PM   #1
Send a message via AIM to john van ommen Send a message via MSN to john van ommen Send a message via Yahoo to john van ommen
Default Why Does The Lab Horn use Two Woofers?
Tom Danley's labhorn uses two woofers on a single throat. So I thought it would be interesting to find out what happens when this is done.
Conventional wisdom says that a pair of woofers will handle twice the power, but with 6db more voltage sensitivity. I've modeled a pair using Martin King's worksheets, and it seems that the conventional wisdom is correct. The SPL is a *little* different, which makes me wonder if there's any advantage with a more restrictive throat or mouth.
What do you think?
:: JD ::
If anyone's interested, this is how I modeled a pair using King's worksheets:
FS is the same for a pair.
QES is the same for a pair.
QMS is the same for a pair.
QTS is the same for a pair.
VAS is double for a pair.
MMS is doubled for a pair ( MMS = 1/(2 * pi() * FS)^2 * CMS )
CMS is halved for a pair (is that right?) ( CMS = VAS / ( 1180 * ( 343^2 ) * SD^2 )
RE is double for a pair.
SD is double for a pair.
*voltage* efficiency is 6db more for a pair. In the graphs, i did series wiring, hence the same SPL.
EBP is the same for an iso pair.
BL is double for a pair. (Note that motor strength has DOUBLED though! Motor strength is BL^2/RE.) ( BL = sqrt ( RE / QES ) * sqrt ( mms / cms ) )
WTB: Vifa P22WP-01 Woofers (surplus 8" Mackie woofers) gtforme00 Swap Meet 9 3rd June 2008 09:57 PM
looking for 6.5inch woofers suitable for a 30 - 35Hz horn... and a small horn too :P SkinnyBoy Multi-Way 24 13th February 2004 05:06 AM
Choosing Woofers for Horn Enclosures asauer Multi-Way 8 23rd January 2004 05:57 AM
FS:SS 8545 woofers, Audaux PR120I tweeters, Volt BM2500.4 Woofers cm7 Swap Meet 0 1st August 2003 01:59 PM
Page generated in 0.06468 seconds (68.75% PHP - 31.25% MySQL) with 10 queries
