I need replacement tweeters for
vifa D26TG-68-06 (6 OHM) and what i believe is a scanspeak TC26TG17 Can anyone advise on some good repacement tweeters? thanks heaps |
#2 |
If you want the same dimension use Scanspeak D2905/9000 but if the dimension is not a problem and you can spend more money use the 2905/99000 revelator. You can find the last one at good price now. He is so neutral, goes very high, and have fs=480 hz. This frequency is very intresting if you use an XO 2nd order at 2500 hz or beter 2800hz. The resonance frequency will be at more 2 octave (no accident in the slope).
I use have try a lot of tweeter but this one is one of my prefered. If i can help you again ... |
#3 |
I use the 7000 from revelator same but has a smalller flange 86 mm excellent tweeter I swapped it from a seas 27 tdc which was good but not as good as the revelator
#4 |
is there anything close to the vifa, we dont have a huge range here
thanks |
#5 |
Contact WES Components enquiries@wescomponents.com
They may have some D26's left.. also, that other tweeter, if its marked TC26, is also a Vifa driver. If you want to upgrade to a more expensive tweeter, then try a Seas or Scan tweeter, but expect to have to make changes to the X-O network. |
#6 | |
27 tg45 06 is a great tweeter vifa |
| tweeters | tonysherwin | Swap Meet | 0 | 22nd April 2008 12:16 PM |
| Tweeters? | ThSpeakerDude88 | Multi-Way | 23 | 19th March 2006 06:59 PM |
| FS: Phy-Hp tweeters | Sjef | Swap Meet | 2 | 29th October 2004 08:33 PM |
| tweeters....... | ermes | Multi-Way | 1 | 17th May 2004 02:00 PM |
| Tweeters | Vivek | Multi-Way | 13 | 23rd October 2001 10:06 AM |
| Page generated in 0.07536 seconds (76.67% PHP - 23.33% MySQL) with 10 queries |
