Old 12th September 2006, 12:41 AM   #1
dmitriy167's Avatar
Default 2-way with 8531G Revelator?
I've abandoned my previous idea for high efficiency, since I realized that my money might be better spent on something of higher quality. The Scan Speak 7" Revelator (sliced cone) driver might be a good idea, especially if I can get a used pair from somewhere since it's very expensive. I haven't seen that driver in any DIY 2-ways (I have seen the Sonus Faber speakers), so I was wondering if anybody here used it in that arrangement.
Thanks,
Dmitriy
Old 12th September 2006, 04:48 AM   #2
Mingo is offline Mingo  Denmark
Have a look at Troels Gravesen's homepage and find SP95 (9500 tweeter) and SP98 (further down the page, I think) (9800 tweeter).
Old 19th September 2006, 04:27 PM   #3
kwng11 is offline kwng11  Hong Kong
mine is 8530K00, bass is very good, mid is quite clear, i think 8531G will be very similar.
mine is only 85.5db in sensitivity, but my Jolida 1701 (50W) can push them very well, so lower sensitivity of this woofer is not any issue to me.
The most i concern is how to get the best crossover to dig out all the goodness of the driver.
let's sharing ideas together~
Old 19th September 2006, 09:10 PM   #4
imjatse is offline imjatse  United States
If you didn't see it Zaph's newest design uses the smaller version of the Revelator:
Zaph's Site
And the local diyaudio thread on Zaph's design:
here
Old 20th September 2006, 12:21 PM   #5
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Recently used the 18W/8531G00 with a S2905/970000 tweeter and a great sounding speaker... my best to date and are my mains. Very critical of the components used in the crossover as well as the partnering equipment.
The inverted drivers were to suit a 1st order crossover but didn't work so is now basically a 2nd order. I don't think the inverted arrangement is having a detrimental effect with 2nd order as it's sounds brilliant.
No longer DIY active
Old 21st September 2006, 02:16 PM   #6
Default Cross-over frequency ?
Hi Rabbitz ,
that ScanSpeak woofer & tweeter combination is basically what I am planning to try !
What nominal cross-over frequency did you attempt the 1st Order slopes ?
I was thinking of attempting it at 2kHz , but am concerned about whether I'll acheive sufficient roll-off to adequately reduce the audibilty of the 18W's break-up resonance which seems to be a little above 3kHz.
Any comments would be appreciated , thankyou ,
Alan
Old 21st September 2006, 03:11 PM   #7
rabbitz's Avatar
I kicked off at 2375Hz and the peak was very noticeable. I then tried several others and even had severe underlaps on the crossover where the woofer and tweeter crossed over at different frequencies up to about 1000Hz. There were over 20 crossovers tried and tested.
None were successful and eventually nailed it with the AR series crossover which gives a steeper roll off on the woofer. What I was hearing was confirmed by Jeff Bagby's series spreadsheet which is invaluable. I'm sure you could use contour networks on the woofer for 1st order but all the others I've seen use a 2nd order as a minimum on the woofer and a good example is the one by Tony G.
Cheers
Old 21st September 2006, 03:34 PM   #8
Thanks rabbitz , and I've just now seen your reply to me in the other Scan thread -{coated versus uncoated 15W's} on basically the same question of mine , and I've replied there-under .
Further , on what you describe above , I realize there is more to this particular woofer than I had thought - 20 trial cross-overs !
I will look at the AR series crossover ; Jeff Bagby ; Tony G ; that you mention .
Really I do not like the audible effects of systems where one driver needs to be connected in reverse polarity to the other , so perhaps I'll have to go to a 4th order crossover if I decide to attempt with the 18W8531 , but even more complexity and I had wanted to keep this one simple !
I wish Scan still had the 8530 - coated cone option - available , that one of the contributors to the other thread said he has , as that would at least have less audible break-up around the 3k2 area . Perhaps I'll have to apply damping to the 18W cones myself ...
I see you have the 18S - sheilded version - for sale on your site , but other than its low frequency behavior being different , I suppose its midrange behavior will be close to that of the 18W - Scan's own data sheet for 18S showed very little difference there to theirs for 18W .
Thankyou again for your comments !
Alan
Old 21st September 2006, 04:19 PM   #9
In a 3 way you likely not need to worry about it, but at the typical crossover frequency for a 2 way (1.5-3Khz) you'll need a notch filter to shape the response to get rid of that 3.2Khz bump, which is clearly visible on both the FR and CSD.
For ideas, take a look at Dan Wesnor's Ella project, and John Krutke's ZD5 project for the kind of low linear and non-linear midrange distortion these these drivers are capable of.
I am impressed with the perserverence. 20 filters? Applying damping?
I think you guys deserve to treat yourself with some measurement equipment, CAD crossover software and some textbooks...
Old 22nd September 2006, 01:44 PM   #10
Thanks for comments tktran303 .
Textbooks I have access to , and if I had the money to afford all the test equipment , etc ... , that I'd like , then I'd be tempted to spend it on good quality manufactured speakers - perhaps from B&W 800 series - but then I might not be completely happy with those and decide to modify them !
What I really need is sufficient time available to do sufficient measurements and constructing , but time cannot be bought !! - as I have no doubt many of the contributors to this forum know too well ...
Alan
FS: Pair of Scan-speak 18W/8531G-00 7" Revelator mid/woofer sholz64 Swap Meet 3 26th September 2008 08:39 AM
Scan-speak 7” Revelator 18S/8531G rekd0514 Swap Meet 2 31st May 2007 03:28 PM
WTB: Scan-Speak 8531G (Revelator) dmitriy167 Swap Meet 3 20th September 2006 04:43 PM
FS: Scanspeak Revelator 18W/8531G Wanderer Swap Meet 1 14th January 2005 02:48 PM
Page generated in 0.11812 seconds (83.93% PHP - 16.07% MySQL) with 11 queries
